just a small project, since i took out the PS pump to remove the ac compressor, it was drained anyway, I figured out a way to use an 81 AC pulley cover over top of the PS pulley. It really finished off the PS pump and looks much better. they all used to have pulley covers at the top of the engine. All i had to do was drill and tap a 1/4-20 hole in the bracket to hold the cover,I then drilled a 1/8 hole and drove in a dowl pin as a locator pin. this lines up the cover and stops it from turning on the bolt. after that i cut off the unused other end of the cover,that used to go under the AC compressor bolt. since this isn't structural,it really only needs to be supported on one end. the metal is plenty strong enugh not to flex. one edge is rolled anyway, i did cut a small amount of that roll and flatten it, this is where the dowl pin is located. right now it's in primer,thats as far as i've got. tomorrow the AC crap comes out,and i'll put it and the pump back in.
