Results 1 to 13 of 13
Thread: Uneven idleing on '88 Accord
    Dec 2008
    Hi guys!
    Its been quite some time since last i wrote in english, so excuse me if my english is bad!
    My problem is that my car isn't idleing properly. Usually it's idleing on 800 - 900 rpms. But when it's cold outside it starts idleing on 1700 - 1900 after a few minutes of driving. This can last from 5 to 30 mins. But my real problem is when I turn the engine off when it is doing this. It's like it is igniting after I have turned the engine off. After this the enginge can be difficult starting again, which it really isn't normally. Seems to me that the problem is the autochoke, but what do you think?
    MysilB
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    Re: Uneven idleing on '88 Accord
    FI or carb?
    Link to my 3geez garage
    Dec 2008
    Forgot to mention that, it's carb.
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    i'm no carb expert but it sounds like leaking vacuum to me
    Jan 2003
    Denmark/Europe
    when your engine runs after you've shut it off, you call it dieseling. It caused by carbon buildup inside the combustion chamber combined with a leaking carb. The hot carbon buildup ignites the small amounts of fuel leaking in from the carb.
    It's usually the cutoff solenoid in the carb that leaks.
    Try to spray water directly into the carb while the engine is running, this will help clean up the carbon buildup inside the engine. You will need to control the throttle at the same time as you spray in the water, otherwise it will stall.
    If that doesnt do it you can try removing the cutoff solenoid, clean it's needle and the seat inside the carb to see if you can fix the leak.
    Jan 2003
    Denmark/Europe
    the idle is probably something to do with one of the idle systems yes. Perhaps the one with the coolant flowing through it.
    You can diagnose it with the shop manual: http://downloads.hondatech.info/Auto...e%20Manual.zip
    Dec 2008
    Thanks for the info and the manual! Will take a look at it soon...
    which motor, some have two carbs
    Dec 2008
    Single carb, 106 hp
    Quote Originally Posted by thegreatdane View Post
    Um....water? I feel a hydrolock thread coming on...
    Not unless you dump a whole bunch of water at once. I've done that with great results.
    Apr 2007
    NW Arkansas
    why not just seafoam it? much more fun!
    i've heard water kills o2 sensors
    not sure how true but i've always avoided getting them wet at all
    Jan 2003
    Denmark/Europe
    Thats why I said to SPRAY the water in. Dont just poor it in...
    Quote Originally Posted by Demon1024 View Post
    Yes water can be dangerous for the inside of an O2 sensor, at least that's the case for a wideband sensor, cant say for sure about the regular narrowbands, but after it's been combusted there's no gasses in the exhaust that werent there already.
    You can buy different products to do the same job, but water is often just as good and much cheaper.
  1. 87 honda accord dx a20a idleing high
    By kotty4643 in forum 3geez Accords
    Last Post: 02-10-2011, 09:13 AM
  2. car is idleing at 2500!
    By 3geeandEF in forum Performance
    Last Post: 06-28-2007, 08:00 PM
  3. idleing weird
    By jetlag in forum EFI Tech
    Last Post: 10-12-2006, 10:25 AM
  4. what could cause the car to sit a little uneven
    By Mantis88LX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-02-2002, 06:56 PM
  5. uneven ride height?
    By FlySquid in forum Classic Honda Community Chat
    Last Post: 05-23-2002, 12:02 PM
