Results 1 to 8 of 8
Thread: Trans problem Any Ideas?
    LX User bank2me's Avatar
    Apr 2008
    88 Accord LX-i
    Portage, WI
    Arrow Trans problem Any Ideas?
    So I changed the fluid in the manual transaxle in my 88 because it had a chatter unless I pushed in the clutch. So it's been quiet for about 2 weeks and today the damn thing is makin noise again. I put new valvoline 10w-30 motor oil back into the transaxle. I just dont see how the fluid would help only for a week? Unless one of the bearing is just cashed. Any ideas on what I should do? I'm going to fix it either way but I just don't want to have to take it in if I dont have to.
    Re: Trans problem Any Ideas?
    Check your fluid level.
    Apr 2008
    88 Accord LX-i
    Portage, WI
    Ill check it 2maro and make sure. Could there be a leak? I mean I must've drained close to 2 quarts out when I changed it.
    i think it takes around 2.5 quarts....if just take off the fill plug and i fill it from the speed sensor...and you know you filled it up to the right level till it stars spilling out of the fill hole
    Apr 2008
    88 Accord LX-i
    Portage, WI
    I checked the fluid and it was up to the hole. I'm not sure where to proceed from here.
    LX User greentee76's Avatar
    Feb 2008
    1988 Honda Accord LX 5sp
    Kalamazoo,MI
    I would check to be sure that the inspection cover/splash shield is tight and not damaged. Also make sure the clutch release arm is returning all the way with the clutch released.
    88 LX 5spd l 32/36 weber l KYB GR-2's l Refreshed A20A3 engine l
    Nov 2002
    Ridin Dirty in New York
    i bet the mainshaft bearings are shot. I wouldnt worry about it, just drive it
    Apr 2008
    88 Accord LX-i
    Portage, WI
    Well I'm thinkin the input bearing is shot. It hasnt been doing it lately so fuckin I'm just going to drive it til this spring til I put in a new clutch and then I'll prolly take the case apart then while I got it out.
  1. 88 auto trans problem
    By Chodaboy69 in forum 3geez Accords
    Last Post: 03-02-2006, 06:55 AM
  2. Exhaust problem? ( Auto Trans Problem )
    By Jay's89Lxi in forum 3geez Accords
    Last Post: 01-18-2005, 04:24 PM
  3. Automatic Trans Problem
    By mhighm in forum 3geez Accords
    Last Post: 10-28-2003, 01:25 PM
  4. trans problem
    By THE_LoserNextDoor in forum 3geez Accords
    Last Post: 09-04-2003, 06:16 AM
  5. weird trans problem
    Last Post: 01-13-2003, 05:41 PM
