here's how to use it, you would put a strip of plastigauge across each bearing journal on the cam,then you torqe on the caps,remove them again and read the gauge on the scale. this will tell you the clearance between the bearing caps and the cam. you compare this to see if it's within honda's specs. on an overhead cam like this,it's just like checking rod and main bearing clearance on a pushrod type engine. this is cheap insurance before you start it up. this way you know for sure the oil clearance is right. once you are done, you just wipe off the plastigage with solvent from the cam and cap bearings. in the case of this engine,you just bolt on the entire rocker assembly,torque it to spec in the proper pattern,then take it back off. then you can read each bearing journal.
I would never install a cam or bearings in an engine unless i checked everything out first. http://www.plastigaugeusa.com/how.html
