Results 1 to 8 of 8
Thread: Tunning A Weber 32/36
    Dec 2006
    1989 Accord LX & SEI
    Springfield, VA
    Hey I have emmisions due... But i have a feeling the with all the emission controls i removed i wont pass emissions. I read on some post the a member would tune his weber and pass emissions... i forget which member it was... but basically need help!!!
    SEi User turabaka's Avatar
    Aug 2007
    Boise, ID
    Re: Tunning A Weber 32/36
    I ended up having to do that to pass emissions. All I did was drive it to the testing place with it tuned normally, then in the parking lot I turned the air/fuel screws all the way in. Got in line, tested it, then turned them back to normal as soon as I finished. Hopefully you pass doing that. I think my test results were like .001 on CO and like 2 on HC. I can't remember what it was at 2500 rpms though. Something pretty close to that I think.
    Dec 2006
    Springfield, VA
    do you have a pic where u could point those out for me i really dont know much about my weber... i had a friend that was a carb expert and he would adjust my carb... i honestly dont know how to!!! i lost the paper that came with the kit also!!!!
    Aug 2007
    Boise, ID
    It's the two thumbscrews on the base of the carb. One's on the front, and the other is on the back. I'll try to find a pick, but I'm not sure I have one.
    Dec 2006
    Springfield, VA
    ok i think i know which ones you are talking about... lemme get this str8 is left for lean and right for rich... or is it vise-versa???
    Aug 2007
    Boise, ID
    yes. turning the screws in tighter is leaner, and out is richer.
    Dec 2006
    Springfield, VA
    thank you!!! i will try this and see!!! THank you again
    keep in mind that was with a 38/38 which has two air mix screws, the 32/36 only has one
  1. Replies: 93
    Last Post: 04-25-2008, 10:42 AM
  2. [Engine & Transmission] Weber 32/36 - 34 - 38 Swap
    By A20A1 in forum How To
    Last Post: 02-28-2006, 11:13 PM
  3. Im Going With A Weber
    By motoracer in forum Carburetor Tech
    Last Post: 09-15-2005, 12:59 AM
  4. Tunning the Carb.
    By zerotap in forum Carburetor Tech
    Last Post: 02-17-2004, 03:07 AM
