everything looks like it is coming a long great, are you goning to put larger cams in? did you change the valve size or compression ratio?
what is the differance between the Accord Si and Prelude Si engines?
I’ll kill you with experience
It's definety coming along good. I just started installing the A20 harness on it today so I should have some pics soon. I will get cams made by Colt after I get the car running. He's close by plus he said it'll only take a day or two so down time will be minimal. Valve size is probably stock BUT I'm not 100% sure. I keep forgetting to ask Mike but I wouldn't be surprised if he did do something to it because he did take the time to get everything else done nicely. The bottom end is stock. It looked to be in good shape plus 9.4:1 compression if fine with me.
As for the difference between Accord and Lude SI, do you mean Lude JDM B20A and Accord JDM B20A?? If so, I don't really know.
www.b20accord.com
