Results 1 to 16 of 16
Thread: Brake Line Help
    Jan 2009
    Brake Line Help
    So I spent a few hours today trying to replace my master cylinder. Searched through the forums, figured out the procedure, bought the new part, etc. The problem I'm having is that the brake line fitting attached into the master cylinder (the one closest to the front of the car) has managed to get itself rounded off . I am using a 10mm flare nut wrench. The 12mm on the firewall and the other 10mm fitting I have been able to take off, its just that one stubborn rounded off one. How do I remove it?
    LX User bank2me's Avatar
    Apr 2008
    88 Accord LX-i
    Portage, WI
    Re: Brake Line Help
    Hey man I would maybe take a vice grips to it.
    Re: Brake Line Help
    Quote Originally Posted by bank2me View Post
    Yup
    find a fresh new pair, small ones with good teeth cuz once you round it off with vice grips it gets worse.
    Re: Brake Line Help
    i was told to just start with using the vice grips, then you wont round it off. and ever since then i havent rounded any
    Jan 2009
    Re: Brake Line Help
    damn, I wish I had just used them at first. I tried a regular combo wrench and they wouldn't budge so I went out and got a flare nut wrench. rounded off fittings are so frustrating :\ any other ways besides vise grips? I just want to have a few different approaches in case one thing or the next doesnt work
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    Re: Brake Line Help
    i always use vicegrips to crack any brake fitting first and its all good after that
    Re: Brake Line Help
    Once you go vice grips you dont go back
    I dont know what else you could have done. I have bought some flare wrenchs metric 10mm and 12mm that are IMHO made wrong. They plain just fit too loose and will round off anything.
    I would look into replacing the line if you can't get it rethreaded into the MC correctly and safely.
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Re: Brake Line Help
    When I come across one that's a real problem, I tighten it a hair, then loosen. Always worked for me.. I wouldn't mess around with anything other than a quality flare nut wrench. Those chinese ones they sell at the parts stores don't always have the correct tolerances... Depending on which line it is, you may have enough to cut and reflare. If you decide to do this, use a quality double flaring tool (not chinese), take your time, and follow the instructions. Replacing the line would probably be your best option though.
    Or you could just vicegrip it.
    CARDONE SUCKS.
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    Re: Brake Line Help
    A vice-grip WILL work It's also perfect for removing a lot of rusted/stuck screws. And lots of other things.
    Even with quality flare wrenches you have to be very careful to avoid rounding the flare nuts.
    Link to my 3geez garage
    Jan 2009
    Re: Brake Line Help
    Vice grips FTW! I got the lines off with a pair of vice grips, and successfully replaced the master cylinder. Thanks guys!
    Re: Brake Line Help
    Vice Grips saves the day. i also did the same crack em loose then use a wrench. Good thing to hear man.
    Re: Brake Line Help
    i sprayed some pb blaster on them before i took it out
    Apr 2008
    88 Accord LX-i
    Portage, WI
    Re: Brake Line Help
    Quote Originally Posted by Blackbird_ View Post
    Fuck ya man cool beans.
    Jul 2002
    a pile of lawn ornaments
    Newtown, CT
    Re: Brake Line Help
    Quote Originally Posted by LX-incredible View Post
    This is exactly what I was taught too. Believe it or not, I actually learned this from a guy at the j/y (see, they're not ALL hacks). First give it one good quick jerk to tighten it a hair, which will usually crack it free, then back it off. But do all of it with a quality flare-nut wrench. Of course, you'll want to shoot it with PB, and if you get the chance and have the time, shoot it each day for a few days before you try it.
    The minute I thrash one with Vise grips (if all else has failed) I replace the line with a new one as soon as I get a chance.
    -Mark D.
    snoopyloopy's Avatar
    Killa Cali
    Re: Brake Line Help
    congrats, glad to be of service. and its times like those that make me want to work on my car instead of send it to a shop. bc we all know that all the guys at an autoshop are doing the best quality job possible. (not to say any of the 3geezers who are mechs don't do quality work.)
    Re: Brake Line Help
    Quote Originally Posted by thegreatdane View Post
    yep i have about 35 of them in different sizes. couldn't live without them.
  1. Protecting brake line?
    By nfs480 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-29-2009, 11:25 PM
  2. brake line help
    By StUpiD8000 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-13-2009, 11:14 AM
  3. Brake Line
    By 89HondaLxi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-27-2005, 06:10 PM
  4. Brake Line?
    By ACE_14 in forum 3geez Accords
    Last Post: 10-19-2004, 07:36 PM
  5. brake line busted
    By od2681 in forum 3geez Accords
    Last Post: 04-23-2004, 04:25 PM
