Results 1 to 12 of 12
Thread: 3g idling in high RPM ?????
    LX User rfiks's Avatar
    Sep 2008
    88 accord hb dx
    el paso
    Question 3g idling in high RPM ?????
    OK- i own a 3g carbed accord hb w/ manual transmission.
    when i start it it idles fine at 1000rpm a little high. but after it warms up the rpms sky rocket. i can tap the gas pedal and sometimes they'll drop (rpm), but as soon as i apply slighted pressure they go back up!
    i know need a new alternator, head gasket and timing belt.
    but im completely stumped!
    i tried cleaning alll throttle linkages and and throttle cable w/ carb cleaner-nothing changed.
    Please help!
    ...If you're ever confused about anything in life... it probably has something to do with money$...
    Sep 2008
    88 accord hb dx
    el paso
    Re: 3g idling in high RPM ?????
    ok.. i replaced the pvc valve and replaced the small fuel filter and seafoamed her-same results.
    but i cant find the big fuel filter to replace it.
    the choke valve stays open and when i close it with my finger the carb sounds like its filling with fuel-(fuel adjustment problems???)
    LX User LxAcc510's Avatar
    May 2008
    1989 Honda Accord LX
    Where they say Hella, CA
    Guessing you got an LX. Check page 90 of the owner manual for the location of the other fuel filter.
    If no one else is going to weigh in then I will. My opinion on carbs is that they will go bad in some creative way at some point and need to be completely overhauled. Some of our carb guys might be able to diagnose the exact problem in the carb, but my vote is always for a complete rebuild when it starts to act up.
    Sep 2008
    88 accord hb dx
    el paso
    i found the other fuel filter it was under the rear drivers side tire. (lol) i had fun removing replacing it (gas eeeveree where).
    thanks guys!!!
    Sep 2008
    88 accord hb dx
    el paso
    mmm... monster...
    oh hey trying to adjust my carb.(no luck)
    and i got a CHILTON book and found where my fast ilde control screw is located i adjusted it but the arm which to screw pushes open to push ??? open stayed away from the screw this adjustment was made per the instructions in the manual(when at oper. temp.)
    ??????? lil help please!!!
    1ajs's Avatar
    slurpeepeg
    its not the carb! its not the fuel filters its your throttle cable sticking
    if the fuel filters work cloged it would not idle high it would be sugish and constantly dieing
    Sep 2008
    88 accord hb dx
    el paso
    what can i do to fixit????
    you need to check #1 that your throttle is closing all the way and #2 that the idle boost dashpot by the throttle linkage is working properly. It should have good vacuum at idle and it should raise the RPMs when disconnected and plugged (DX, LX only, vacuum hose #6 according to my shop manual). There should be vacuum present at the hose at idle.
    To check if the throttle is closing all the way just look down the throat of the carb. To check the idle boost dashpot apply vacuum to it and you should see it move. If it leaks the vacuum replace the dashpot
    The screws SHOULD NOT need adjustment as you are only masing the problem
    use this:
    http://www.pauldesign.ru/honda/shopm...trols_carb.zip
    remember, this is an overseas manual so it is a little different from North American cars
    http://www.pauldesign.ru/honda/shopmanual.html
    DX User 87acc's Avatar
    Nov 2008
    87 honda accord Hatch S
    Agassiz, B.C.
    Once you start to drive do the rpms go down? cause mine does that to and what i was told it that its the auto choke kicking in because it thinks the cars still cold. after a couple of minutes of driving my rpms drop back to normal. i havent been able to fix it in my hatchy either.
    Custom 87 honda accord S.
    new 17 inch rims
    custom intake and hoodscoop
    Jan 2007
    1986 accord dx
    nepa
    I just started having a very similiar prob. I have an 86 DX. It seems like the choke is sticking open. I tinkered a bit today and when I close the choke it will idle down but runs really ruff like a timing prob. She ran great until the other day. Don't know if its related but the voltage light came on the same day it started giving me a prob.
  1. Idling very high, especially when hot
    By Austin's 86 LX in forum Carburetor Tech
    Last Post: 09-01-2011, 08:56 AM
  2. idling
    By chowder in forum 3geez Accords
    Last Post: 06-19-2008, 03:53 PM
  3. Carb is idling too high
    By 82h in forum Carburetor Tech
    Last Post: 11-02-2004, 08:57 AM
  4. Failed Emissions: High HC ppm's & High CO%
    By 98serwtricks in forum 3geez Accords
    Last Post: 06-15-2004, 09:24 AM
  5. idling
    By D Glad in forum Performance
    Last Post: 07-08-2003, 08:57 PM
