Results 1 to 25 of 29
Thread: Strange noise from rear of engine compartment.
    LX User mephi's Avatar
    Apr 2004
    1987 Accord DX 4 door
    Port Orchard, WA
    I just got my DX running again today, everything runs ok, idle is great once it warms up, but I still have to adjust the timing.
    Anyway, there is this weird rotational dragging sound from the rear of the engine compartment, sort of like an alternator bearing going out. I might have just answered my question, since the alternator didn't seem to fit in quite right.
    Has anyone else had a similar experience and figured out what it is?
    LX User OldSkoolA20accord's Avatar
    Apr 2008
    88 Accord DX
    limestone, TN
    Re: Strange noise from rear of engine compartment.
    i think you did too. thats the only thing rotating in the back of the engine at idle.
    88 DX hatch.
    Apr 2004
    Port Orchard, WA
    I think the previous owner might have screwed something up back there. Anything about the install of the alternator that is easy to screw up? I heard something about a washer, but there wasn't one when I took the thing off before I pulled the engine.
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    take the belt off, run the motor for aslong as it take s to find out if its the alt bearings.
    you wont over heat the motor or anything aslong as you dont leave it running for to long
    or just take the belt off and spin it by hand and see if the bearings are noisy
    Apr 2004
    Port Orchard, WA
    Anyone have a good way of getting the alternator out without pulling the drive shaft?
    Is the belt rubbing on the timing cover? Sometimes they do that and you just have to wait for them to wear until they aren't touching anymore.
    Before you pull it, did you try spinning it like above suggested? Might be able to figure out if it's rough or noisy or something that way.
    Apr 2004
    Port Orchard, WA
    Well, it's not the alternator. I removed the belt and spun it by hand and it had no problems. Ran the engine for about 30 seconds without the belt and the noise is still there. Any thing else that could make a noise like that? Maybe something in the exhaust? I don't think I would be able to hear an oil pump going out, and it doesn't really sound like it's coming from there. Transmission bearings sound different.
    Agh...
    Apr 2008
    88 Accord DX
    limestone, TN
    is it a 5 speed? if so it could be the throw out bearing.
    maybe your muffler bearings are going out!
    88 DX hatch.
    Apr 2008
    88 Accord DX
    limestone, TN
    get a video of the noise and where its comint from. it would help out alot.....
    88 DX hatch.
    Quote Originally Posted by OldSkoolA20accord View Post
    timing belt tensioner? get a piece of rubber tube, stick one end in your ear,now move it around until you hear the noise.
    Apr 2008
    88 Accord DX
    limestone, TN
    damn i didnt even think of that. money sayd that is what it is. even tho its on the side of the engine not the back. the hose thing is a good idea.
    88 DX hatch.
    He is one sound a bad tensioner can make.
    http://s37.photobucket.com/albums/e5...t=S6301315.flv
    Apr 2004
    Port Orchard, WA
    Just replaced the tensioner. I'm taking it in tomorrow to get an expert opinion. A free expert opinion. I'm starting to think (hope) that there may just be something wrong with the exhaust...like muffler bearings...
    just got it running? what did you do to it?
    Apr 2004
    Port Orchard, WA
    I pulled the motor, replaced the oil pan, valve stem seals, timing belt and tensioner, front and rear main seals, rebuilt the distributor(sorta), resurfaced the flywheel, replaced clutch cover (previous owner just replaced the clutch, and neglected to do these things), replaced the water pump, flushed the cooling system, removed all of the vacuum lines, and cleaned up the block a bit. Engine removal may not have been necessary, but it made the whole process easier.
    Then I put it back in and started it back up. If it hadn't snowed up here 3 weeks ago, I would have been done by now. Today I set timing, put newer tires on it, and fix a headlight wiring problem. Then I have to swap out fenders and bumpers with another car.
    Apr 2004
    Port Orchard, WA
    The noise was coming from the transmission. I noticed that whenever I stepped on the clutch it went away. The funny thing though, is that after I drove it for 5 miles it went away. I'm going to see if it happens again tomorrow, the next time I drive it. I have to fix a headlight wiring problem before I do that though. Wires got pinched between the rotating part and the body.
    Quote Originally Posted by mephi View Post
    Throwout bearing.
    2.0Si User cubert's Avatar
    Feb 2003
    2012 Civic si, old bikes.
    NH
    I was under the impression if the TO bearing was bad, it would make noise when the pedal is depressed, and the input shaft bearing is bad if it makes noise when the pedal is up...
    Apr 2008
    88 Accord DX
    limestone, TN
    My friend had an eclipse. It would make a weird ass noise only until the car was warmed up. same with my friends civic. The throw out bearings were bad on both.
    It always made the sound, at idle and while driving only went away when it was running for like 2 hours.
    88 DX hatch.
    That is true. There is a possibility that the clutch is adjusted so that the throw out bearing constantly spins, but once you depress the pedal it puts pressure on the bearing and it stops groaning.
    Apr 2004
    Port Orchard, WA
    Forgot to mention that I replaced the throwout bearing. I adjusted the cable to have about 2-3mm of play as per the manual I think I might go ahead and loosen it up just a tad bit.
    I'm going to school right now for automotive repair, and I talked to one of my instructors who used to be a tech at honda. My transmission had 90 weight in it when I pulled it, and he said that can cause serious problems for 5th gear. It doesn't flow as well as it needs to and doesn't lubricate the bearings out there very well. Since it stopped after I drove it for a little while, I think that may have been the problem--used new motor oil in it, again, as per the manual. I'm going to test it again in the morning after I fix the headlight wiring and see how everything is.
    I thought you can only hear 5th gear when driving if its going out?
    Apr 2004
    Port Orchard, WA
    could have been the main shaft bearings too. They'll spin with the clutch until you engage it.
    SEi User codyJDM's Avatar
    Apr 2008
    '88 civic wagon
    SoCal
    My 5th gear has been making noise for months now and hasn't killed itself?
    i would not do that tooo much....mine started making noise and the day i deside to go to a long distance meet my trans got stuck in 5th gear going uphill....killed the clutch....not fun at all....then i changed out the oil with honda mtf and it helped a bit till i had enough money for my rebuilt trans and new clutch
  1. strange noise
    Last Post: 03-26-2007, 11:16 AM
  2. strange engine grinding noise
    By T-Funk in forum 3geez Accords
    Last Post: 09-07-2005, 04:09 PM
  3. Rattling noise in engine compartment
    By biggene in forum 3geez Accords
    Last Post: 04-18-2005, 04:53 AM
  4. Strange engine noise
    By meangreenLXi in forum Performance
    Last Post: 03-09-2004, 07:58 AM
  5. loud clicking noise in engine compartment!
    By Sharky196 in forum 3geez Accords
    Last Post: 03-31-2003, 08:16 PM
