Results 1 to 25 of 28
Thread: Torque Wrench: recommended replacement
    Dec 2007
    I had a $35/$40 craftsman 3/8" torque wrench that I broke while using to try to loosen the lug nuts on a friends car...yeah yeah, I was in a pinch.
    Sooo, I'm in the market for a new one. It doesn't have to be fancy, but I'd like to be able to use it for pretty much anything important. Here are the upcoming jobs that I'll need it for...
    - trans. fluid and filter replacement
    - new brake master cylinder replacement
    - new oil pan gasket replacement
    1. recommendations?
    2. will I be able to get by with a torque wrench that measures down to 10 ft/lbs, or will it need to go lower? If it needs to go lower, what types of jobs would require it to go lower?
    Thanks! - possibly more questions to come.
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    Re: Torque Wrench: recommended replacement
    Tsk tsk, not supposed to be loosening stuff with a torque wrench. Buy a breaker bar or get a piece of pipe that you can slide over the end of a 1/2" drive ratchet.
    Anyways, I'd say pick up another craftsman torque wrench. I wouldn't trust a cheap harbor freight special.
    And you really shouldn't need a torque wrench for the jobs you have listed there.
    since it's a Craftsman, aren't they lifetime warranty.
    You can bring back to Sears and get a replacment. I dont think they need a receipt for warranty exchange. I could be wrong about the replacement exchange but it's worth a try.
    Dec 2007
    yeah that was my understanding when I bought it from sears, but after a quick searches after it broke, I found out otherwise.
    Dec 2007
    based on my research, putting an oil pan back on after replacing the gasket without residual leaks can be a real bear if not torqued to spec...
    SEi User ZackieDarko's Avatar
    SnapOn digital
    mmmmmm best tool EVER even vibrates when you hit the ft/lb or in/lb your select
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    snap on are rip off artists
    there are better for less
    sykes and pickvant are good
    get a 1/2 and a 3/8 drive one
    1/2 are better for the bigger thigs like head bolts/flywheel bolts
    Quote Originally Posted by ZackieDarko View Post
    SnapOn digital
    damn skippy! i got 2 of them for sale. 300 each. from 5-100ft/lb
    I also got a regular snap-on one for 110 for my 3geez members(hehe) it goes from 10-70 i think...
    "rip off" or not they make the best TQ wrench I have EVER used digital/non-digital
    AND it makes little beeps which are neat
    If I were to get a new torque wrench, I'd get a digital one. To do an oil pan, you need one that goes under 7 ft/lbs. Most torque wrenches are not accurate at their highest and lowest settings.
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    A lot of what Harbor Freight sells is junk. However, their torque wrenches seem to work well. Everyone I've read about that had his calibrated or tested found that the error was less than 4%. I've tested my 3/8" against a known good beam-style wrench with excellent results before each use on critical fasteners (con rods, head bolts, etc.).
    For the oil pan you probably want a 1/4" torque wrench so you'll be in the right range as mentioned above.
    Mike
    If money were no object, I'd buy a Snap-On. No questions asked. Money is an object however, so I use a Home Depot (Harbor Freight equivalent) cheapie. It goes from 0-150 lbs. It's a half-inch, click type and it works wonderfully. I've never broken anything with it and never had anything rattle loose. I use it to remove lug nuts and to torque lug nuts to exactly 80 ft-lbs. I wouldn't worry so much about accuracy as your wrench would have to be wildly inaccurate to cause problems. You will probably lose more accuracy the first time you drop it or leave it set overnight than it will have out of the box. You absolutely need a torque wrench to do your oil pan properly.
    I use a torque wrench on every bolt. Every bolt from the cruise control actuator mount bolts to the CV spindle nut. Every bolt.
    Sep 2007
    new zealand
    not sayin they are bad tools, just way over priced is all.
    have had a few snap on spanners and screw drivers and they no better than tools quarter the price.
    if anything i prefer my $20 spanner set to my old snap on ones which were ten times the price
    Other tool companies make tools for them so the main benefit is excellant customer support, uniformity, and guarunteed quality.
    I have a mix of brands for my hand tools but I must have a snap on ratchets and test lights.
    I would use an inch LB torque, or one that is capable of going into inch lbs and ft lbs. I do use a snap on for that though since it was convienient to get one from them. Sears is ok too, again, convienient.
    digital tq wrench :O I WANT ONE
    Washington
    armstrong is all i own for torque wrenchs and ive got a 1/4-1/2-3/8 and i love them all. the price is less than snap on and the only thing they wont do is torque in reverse like some of the snap ons. the good news though is unless your working on a ford you dont use many reverse thread bolts.
    Sears sucks, snap on is over priced and they wont honor there warrenties for me. harbor freight is great for cheap one time use tools but dont trust on something like torque specs.
    I got sockets from Harbor Freight that have taken a huge beating, and they're still good. They are, however, 1/2" drive impact sockets.
    Quote Originally Posted by OptimusPrimeSr View Post
    naw take that bitch in the only thing i can think of thats craftsman that isent under the lifetime warranty is the power tools
    snoopyloopy's Avatar
    Killa Cali
    first, i'd try taking it back to sears and try there. (unless you'd waste as much time as it'd cost replace.) if that fails, then depends on how much you use your tools. i got all my torque wrenches from (gasp!) harbor freight, and they've all seemed decent to me so far. especially considering that i use them almost never. for the jobs you listed, i don't think i even torqued my bmc (seeing my wrench is kinda big). i'm assuming you're auto though since you said you're replacing trans filter? if that's the case, you might run into a few bolts that you want to torque in that whole process. and for the oil pan gasket, i'd definitely torque the bolts to the block.
    Nov 2000
    Talking Re: Torque Wrench: recommended replacement
    Man, I thought I was compulsive. LOL
    LX User OldSkoolA20accord's Avatar
    Apr 2008
    88 Accord DX
    limestone, TN
    sears took my craftsman torque wrench back when it broke. i didnt even buy it there.
    88 DX hatch.
    Jul 2002
    a pile of lawn ornaments
    Newtown, CT
    While I'm not all that nuts when it comes to torque'ing down everything to exact specs.... ...in fact, there's only a very small handful of parts that I do stress on getting to exact specs, and oil pan gasket is definitely one of them.
    I'm with Roo on getting an in/lb 1/4" wrench for the oil pan, as that needs a very low tq, and with too much tq, you'll have a hell of a time getting a leak free job.
    Anyway, I have a friend that works for snap-on, and he does agree that they are very expensive, but the benefit, as has already been said here, is their customer service is great, and their quality control on the tools they produce, or have produced for them, is great.
    What I'm a big fan of with Snap-On is that I can buy a tool from them, and pay weekly or monthly on it until it's paid off. I just give them my cc or debit card info, and they automatically charge me a set amount until it's paid off. Makes it hurt less imo.
    That said, I have a cheapie harbor freight 1/2 clicker (up to 150 ft/lb) that I use on basically nothing, but have it incase I need it, and I have to admit I'm not upset at all with its quality. I'm confident in using it when I have to, and for the $20 it cost me, if I break it I'm not going to cry over it. I have used my kick ass S*K 250 ft/lb clicker (it's a huge wrench) for axle nuts, flywheel bolts, etc, and it's proven very useful, and for the price (i think it was 130) I feel I got a good tool for a good price.
    hmm.... I wonder if we should start a sub-forum in mechanical for tool reviews?
    side note, for lugs, I never use that stupid lug wrench as it's bulky and always gets in the way of everything. Instead my weapon of choice is my 24" long 1/2" breaker w/ a long 19 impact socket. ...for those ugly stubborn beasts I break out the answer to anything, my trusty 42" long 3/4" breaker. I have yet to find anything that beat that wrench.
    -Mark D.
    Jul 2002
    Newtown, CT
    Quote Originally Posted by OldSkoolA20accord View Post
    Given that Sears (I know KMart now too, but that's only because Eddie used KMart to buy Sears) is the only one that sells Craftsman tools, because they own the name, and they have a lifetime warranty on tools (not always electronics), if it's broken and you bring it to them, they usually always replace it with the exact or comparable tool. Good luck
    -Mark D.
    Sep 2007
    new zealand
    the only bits i actually ever worry bout torque specs with is bits that a directly tied to the engine running and staying in working order.
    engine internals,flywheel,oil sump,cam pulleys and associated tensioners.
    every thing else you sort of know if its tight enuff by feel.
    i must admit that snap ons customer service is good.
    our rep is always sticking his head in the door( prob chasing another sale tho)
    to see how things are goin.
    think there is room for a tools review section eh.
    no, but seriously?
    don't joke around like that....
  1. Best Torque Wrench?
    By vteckiller in forum Classic Honda Community Chat
    Last Post: 05-11-2012, 04:35 AM
  2. Master Cylinder: recommended replacement?
    By OptimusPrimeSr in forum Classic Honda Community Chat
    Last Post: 01-23-2009, 06:17 AM
  3. Spark Plugs: anti-seize & torque wrench
    By w261w261 in forum 3geez Accords
    Last Post: 11-01-2005, 05:47 AM
  4. Torque Wrench - Messed Up?
    By it's paid for in forum 3geez Accords
    Last Post: 12-20-2003, 03:25 PM
