First the car is an 89 DX.
Ok, problem is when I start the car in the morning, it fires up on the first crank and after about 10 seconds it seems like its going to stall. If I stand on the gas I get it to stay on. When the engine temp get up to about 170 degrees the idle jumps up to 4k rpm and will bounce from there to 3.5k. It will do this for about 15-20 minutes. After reving the motor to try and get the idle down, it will finally fall and after this it will idle, run and drive normal.
Has anyone ever experienced this before?
