Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 107
Thread: My 1988 Honda Accord Lxi, Still Under Consruction
  1. #51
    1991 Civic STD
    Arbutus, MD, Baby
    Re: My 1988 Honda Accord Lxi, Still Under Consruction
    No suggestions, but damn you've got a nicely modded car.
    You guys are making me miss my old 3G. I want another one now.
    Daily Drivers Done Right
  2. #52
    the neddles just pop up
    DX User 1988HondaLXIAccord's Avatar
    Jan 2008
    1988 Honda Accord LXI
    Batavia, Ohio
    Thanks speedpenguin, and that is how i broke the tach needle, i tried to pop it from the very bottom and the base split. This is what i really want to do to the gauge cluster.
  4. #54
    Jan 2008
    Batavia, Ohio
    Here is some pic of my upper rear strut bar
  5. #55
    Joay's Avatar
    Sep 2008
    Misty Beige 1988 LXi Coupe
    What kind of tie bars are those?
  6. #56
    Jan 2008
    Batavia, Ohio
    Megan Racing, they are from a 4th gen accord but with a little modification to fit mine, i am in the process of making high nuts for the front strut bar so that it will clear the intake
  7. #57
    Joay's Avatar
    Sep 2008
    Awesome what needs to be modified to get them to fit?
  8. #58
    Jan 2008
    Batavia, Ohio
    The rear lower needs part of the jack hump cut out, the upper rear strut bar just needs the arms to be cut and repositioned and welded, and the front is the hardest cause you have to make spacers or do the top hat mod to clear the intake and then drill one hole on one arm, and then cut and reposition the other arm to fit
  9. #59
    Jan 2008
    Batavia, Ohio
    OK i know you can modify a b16/b18 intake to fit the a20a3's, do you think it would be possible to do it with these, they are for the b16/b18 motors.
  10. #60
    Joay's Avatar
    Sep 2008
    Looks like they'll hit the firewall. The flange is the hard part though, you can always modify the runners.
  11. #61
    Jan 2008
    Batavia, Ohio
    true the reason i asked is cause my wife said that if it will work i can get them, sucks that she has my money though :P
  12. #62
    bad ass looking intake - no dimensions on the website??
  13. #63
    Jan 2008
    Batavia, Ohio
    Hey quick question guys, i have a MSD 6400 box, what and were does the green and purple wires go and connect to, this is my first one, so please help, Thanks
    And Thanks chillphillyphil
  14. #64
    Jul 2002
    a pile of lawn ornaments
    Newtown, CT
    no idea on the MSD, but I can tell you that the ITB's will work (as long as you have clearance, which should not be an issue). I've been holding out for a while on bringing these up, but since you did, I guess it's already out there.
    Unlike the DCOE setup (carb) you don't have to worry too much about the angle of the runners, ITB's, so you honestly can just do the very slight modification to the flange (Drill two additional holes, and egg out one more), and you can cut off the water nipple too, or just leave it as long as it doesn't get in the way (and it should not be in the way). To be perfectly honest, this will be equally as easy to install on a 3G as it is on a Civic/Teg.
    I would take the chance to convert to OBD1 while you're at it too. Please do this, because I'm dying to see what sort of power gains you get off this, and other than 'justanothermike' who did this some 7+ years ago, you'll be the only other one to have ITB's in their 3G. Do it up man.
    -Mark D.
  15. #65
    Jan 2008
    Batavia, Ohio
    My plans for the motor is to get rid of the vaccum box, do an obd-1 setup, do my ignition, the itb's, do a port and polish and port match the head the intake and exhaust, bore the motor .20 over, and find someone that make flat top pistons. I have my suspension almost done all i am missing is coilovers and my ST sway bars, so i am starting on the motor next, then the body
  16. #66
    DX User 89lxisedan's Avatar
    May 2009
    westford, massachusetts
    Quote Originally Posted by 1988HondaLXIAccord View Post
    where di you find that?> and how much is it
  17. #67
    Jan 2008
    Batavia, Ohio
    Here is the website and they are $750.00, which to me is not bad for these setup
    http://www.ultimatemotorx.net/itbinthbob1.html
  18. #68
    Jun 2009
    Smile Re: My 1988 Honda Accord Lxi, Still Under Consruction
    Nice Car looks clean
  19. #69
    thats cheap....that is about how much i paid for my skunk 2 set up...i would not mind slapping some of these
    Check my thread in the suspension section, i got a simi how to on the rear bar. And i was gonna do the front but lost interest lol.
    but Very nice looking mods man.
    You deff are gonna surprise ppl on the street.
  21. #71
    Jan 2008
    Batavia, Ohio
    Hey thanks guys, to be honest i did not know what the hell I was doing before i found this website, you guys have helped my a lot.
  22. #72
    Jan 2008
    Batavia, Ohio
    Ow and does anybody know someone that that can tell me what the green and purple wires of my Msd Box get hooked up to, i know they go to the igniter inside the distributor, but the is four wire 2 blue, black/yellow, and a green
  23. #73
    Feb 2004
    89 accord lxi
    down by the bay
    The green and purple don't do anything. But you can hook up a switch to jump them together and disable the ignition.
  24. #74
    Jan 2008
    Batavia, Ohio
    Thank You Guys
  25. #75
    May 2009
    thanks. if it bolts up i'ma get one
  1. 1988 Honda Accord Lx -JTM-
    By JTM in forum Newbie Introductions
    Last Post: 09-05-2007, 08:19 PM
  2. 1988 Honda Accord LX
    By blazin3gen in forum Trading Post
    Last Post: 11-11-2003, 10:30 PM
