Page 3 of 3 FirstFirst 123
Results 51 to 74 of 74
Thread: Megan Racing strut bar done!
  1. #51
    Re: Megan Racing strut bar done!
    it took me fucking forever to get the bushings the right size. but thats cuz i didnt have a dremel.
  2. #52
    SEi User turabaka's Avatar
    Aug 2007
    Boise, ID
    you cut the bushings? I'll be that did take awhile. I just modified the vigor brackets to work on the Accord.
  3. #53
    ^^ explain.
  4. #54
    Aug 2007
    Boise, ID
    I took the brackets for the vigor bar and redrilled the bolt holes so that they would fit the accord chassis. That allowed me to reuse the bushings from the vigor.
  5. #55
    thats really fucking simple. why didnt i think of that?
  6. #56
    Thats what i did
    shut up fagots. lol makin me look bad.
  8. #58
    rear sway bar FTW
    DX User Haxxorz's Avatar
    Jun 2009
    1988 Honda Accord DX
    Portland, OR
    Alrighty! Just back from the junkyard and found a 92' vigor with its rear sway bar. I kinda failed at preparation and only brought crescent wrenches cuz I thought that they were just bolts and nuts. EXCEPT most are hard to reach... and so I can't get any torque on them, but I borrowed a socket from the shop and got everything.
    Here's my question: I got everything except the two brackets more towards the middle of the car. they had like 3 fatty bolts each that I couldn't get to the other side of them without dismantling more. Did I need those brackets? each had one bolt holding onto the sway bar.
    I'm going to make it work somehow, just need some insight lol.
  10. #60
    Aug 2007
    Boise, ID
    Quote Originally Posted by Haxxorz View Post
    If you don't already have them then yes you need them. You can use the accord ones. You just have to cut the bushings bigger. I think it's easier to just use the vigor bushings though since you only have to modify the brackets a little bit to work.
  11. #61
    Jun 2009
    Portland, OR
    crap, So its better to take the brackets off the vigor and use those instead of the accord ones? That's what it sounds like most people did. Looks like i'll make another run into the junkyard and grab those.
    And then i'll replace the accord stock ones with the vigors? so it'll fit the bushings correct? I know I can assemble the rest, just gotta get my car elevated a bit. I've got a drill and a bunch of bits so I can redrill the holes.
  12. #62
    Aug 2007
    Boise, ID
    yes. Since you have a DX you should just grab the vigor ones since your car doesn't have a rear sway bar. Meaning you have no accord brackets.
    you just redrill the holes in the vigor brackets so they line up with the holes on the accord chassis. There's only two holes on the accord though, and 3 on the vigor brackets so one of the holes won't line up with anything.
  13. #63
    Jun 2009
    Portland, OR
    Bleh, I went back the junkyard and got the brackets no prob. Figured out where to drill and went ahead mount them in the correct 2 spots available. But its interferring with the axle? Or something.... Not enough room between the bracket and the frame/axle. Sooo annoying.... Here's some crappy cell phone pics of what I mean. I tried bending back the brackets a bit but they are seriously tough. (prolly a good thing lol) Any suggestions?
  14. #64
    Aug 2007
    Boise, ID
    do they rub when the car is flat on the ground or only when it's jacked up? I remember my sway bar rubbed when I jacked the car up, so I thought it didn't fit at first.
  15. #65
    Jun 2009
    Portland, OR
    Yeah it was when the back was jacked up. Will it fit if its on the ground? Ugh... That'll be fun to get too...
  16. #66
    Aug 2007
    Boise, ID
    yeah try doing it that way. Actually I think what I did was jack the car up, put it on jack stands, and then jack up the wheel knuckle so that it moved that part of the suspension out of the way enough to bolt the bar on.
  17. #67
    Jun 2009
    Portland, OR
    Hmmm, okay. I got jack stand so I can prolly do that. Thanks for the help turabaka its appreciated. =D
    I'll try it out tomorrow and let you know how it works...
  18. #68
    Aug 2007
    Boise, ID
    yep no problem maing.
  19. #69
    yeah that rear sway bar will help alot
    Jun 2009
    Portland, OR
    Holy jumpin monkeys! Yeah its defintiely a night and day difference over NO sway bar. LOL
    I got it done after ALOT of modifying the brackets. One side fit fine after redrilling the holes but the other wasn't... Like a mutant or something lol, after an hour or two JUST for that bracket I got it to finally hold everything. and then I bolted everything back up.
    Its sexy how it handles now; except on the right side, the bar is right next to my exhaust pipe and on my bumpy gravel driveway it makes noise as it bumps against it. (going 60 on the road its fine though) whatev. I guess I'll call a muffler place and see if they can just re-pipe that one little section before the muffler as to not hit the sway bar. Other than that she's lookin good. ^^
    I would post some pics but i'm too lazy to upload to photobucket rite now...
  21. #71
    yup...good stuff
    i painted my sway bar silver
  23. #73
    x2 i agree ^^ wannabe st lol
    i think they are the same size...lol one is just solid the other one is not as heavy...i compared mine to my st front sway bar...almost looked the same
  1. Megan Racing 4-2-1 Stainless F22 F23 Header , Modification / Install
    By A20A1 in forum Restoration & Custom Fabrication
    Last Post: 05-04-2014, 06:21 PM
  2. Megan racing Lower tie bar - $40 shipped
    By frantik in forum For Sale
    Last Post: 07-13-2010, 01:21 PM
  3. Megan Header, how good are they?
    By F22B1VTEC in forum Performance
    Last Post: 09-06-2007, 01:16 PM
  4. ok BOMZ or MEGAN or what???
    By Integral in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-25-2005, 07:29 AM
  5. Megan Racing Inc
    By mattalica in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-28-2004, 06:18 AM
