so i did some research and looked at the shop manual and i want to make sure that the adjusting points i'm trying to go for are the right ones. now i'm not trying to adjust the actual sealed beam bulb for beam placement, but the actual casing the sealed beam bulb sits in. i need it moved down about 1/4" at most. but i'm trying to find the adjustment screws for how far the headlight pops up. now on the shop manual it shows three adjustment screws behind the headlight casing, but i'm not sure if that really adjusts the height at which the beam casings come up or not. input welcome!
