Results 1 to 8 of 8
Thread: need some help...
    Apr 2008
    88 accord lx
    Hillsboro Oregon
    Question need some help...
    so my car hasnt ran since july i think and i just gave up on it but i figered just to save some money on buying a new one id come back here.
    anyways, to put this the easiest way i can, it will turn over and start (sometimes) but it wont idle. ive checked the vac lines, i just dont know what could be causing the problem. anyone else with this problem?
    LX User greentee76's Avatar
    Feb 2008
    1988 Honda Accord LX 5sp
    Kalamazoo,MI
    Re: need some help...
    Did you check the line the pcv valve is in? If that line cracks it is a BIG vacuum leak.
    Are you getting fuel? spark?
    88 LX 5spd l 32/36 weber l KYB GR-2's l Refreshed A20A3 engine l
    Apr 2008
    88 accord lx
    Hillsboro Oregon
    im getting fuel and spark because it'll run if i keep my foot on the gas. if i shift into drive i need to use the break as a clutch and rev the engine to keep it fromdying as well. i think that is just needing tranny fluid though.
    Apr 2008
    88 accord lx
    Hillsboro Oregon
    and no i didnt check the pcv. where is that at?
    Feb 2008
    Kalamazoo,MI
    On the intake manifold in front of the carb you will see a hose that comes up, makes a U and goes back down to the manifold. The valve itself sits in a hole on the manifold on the left side of that U. If that all looks good the hosing continues down below the manifold to a breather box on the rear of the engine.
    Carb or injected?
    Feb 2008
    Kalamazoo,MI
    Carb or injected?
    Good question. I assumed since he was posting in carb tech that it was carbed?
    Apr 2008
    88 accord lx
    Hillsboro Oregon
    yeah it is carbed lol.
