Hi everyone. Somebody remember me about "car works on 3 cylinder" thread. Then problem fix with a complete rebuild of head. Now it's good (car works on 4 cylinder finally) but I have some carb problem now that I haven'r before head rebuilding:
-At cold car smoke black (reach mixture issue), and idle not going up anymore (fast idle doesn't works) but stay at 1000rpm very roughly
-When car is very well warmed up, smoke go off but idle and run still rough.
-Whose rebuild me the head told me throttle float on carb was open all the time both cold or hot car (so air float throttle open means choke closed....right?), and this is the reason why car start difficulty at cold. Yes, I knew about this issue so mechanic is correct.
Here is the matter: he fix air throttle to stay closed (choke opened I guess) when car is cold...and now these are problems.
-He rolling back at the previous situation but car still run roughly
I scare about mechanic touch something on carb that he doesn't know at all because these carb are a very pain in the ass when u going to try some setting...
How can I fix this? There's a write up that I can follow to fix it?
