Thanks 89sei89dx, Ill go and check out my car sometime soon and see about getting this done. Maybe take some pics and make a how to.![]()
thanks for the info on the thermovalve, the one was plugged when i got the car so i left it that way and i wasnt sure about just plugging the other one also. i didnt think of it really.also my car threw the code 12(egr) since i got it. and what does the thermovalve do![]()
negative, i've had mine unplugged for a week now and have no code thrown, or the PGM-FI light on. so i'd say we're clear for lift off...plus i plan on having a plate machined for the EGR, as well as others.
1987 Honda Accord LX-i (A20A3) (179k)
79-whp, 103-wtq (Performance Solutions)
"...if you type, 'Google' into Google you'll break the internet..."
Yeah helpful ain't it that its so easy but there's no part to do it. Kinda like the "swap a b20" "h22 cant fit" spam thats floated around here for the last 5 years.
What are you trying to accomplish BTW? there is nothing wrong with the MAP sensor setup on our cars and I'm pretty sure OBD 1 uses one also/
well i'm just trying to clean up my engine bay so there's not a bunch of useless shit laying around. most of the vacuum lines are for emissions crap that aren't in anyway detectable if you reroute things in the right way. and i still have my MAP sensor setup, as well as the ignition sensor setup. i plan on taking pictures of my change to the vacuum box just as our other friend did, 'cept i'm mounting my sensors to the firewall using, "L" brackets. so...patience, pictures will come.![]()
I believe the thermovalve on the thermostat housing shuts off vacuum to the outer vacuum port on the distributor when the car warms up. But then FI engines also have that ignition solenoid which also seem to do that. So I guess I'm not completely sure, and at the moment I'm too lazy to study the diagram.
C|
Yeah, this turned out to be a lot easier than I thought it'd be. I need to run the code on the computer since my PGM-FI light came on twice when cruising over 65-mph...reporting in soon with further info.
u got any pics of it done . i wanna see what u did
yeah. ive done it but i wanted to see it done on someone elses car on here.
it's a 260-grind, and the only thing needing to be, "reset" is the valve clearance
yep, like 3rdparty said. He ended up going with a 260 like delta recommended, and I ended up going with a 272. No problems so far, and a bunch more power. No bottom end power though. took a bit of getting used to. Stalled it a few times and pissed off the people behind me.
dude this is fuckin helpful thanks im try this on my car maybe this summer or somthing
