Results 1 to 25 of 38
Thread: loud "spring" noise front front
    I notice when I turn the wheel all the way to one side and then move the car, something clicks or makes a "spring" like noise.
    it's coming from the drivers side front wheel. i can also cause it to happen by bouncing the frame near the wheel.
    i'm assuming it's a ball joint or some shit but which one?
    Re: loud "spring" noise front front
    Which ones have you not replaced?
    SEi User 86ccord's Avatar
    Middle Georgia USA
    well on my mazda truck, when i turn to sharply a bold head knocks against the frame.. so it could be that...
    one day I'll return.
    i havent replaced any of them
    Jack up that side of the car and give the wheel a good tug. I use a crow bar on the lower ball joint to check for play.
    pico shop time
    carotman's Avatar
    Montreal South Shore
    Hmm the only ball joint I can see making such a noise is the lower ball joint.
    Here in Canada they're prone to failure. Does it sound like a squeaky mattress?
    I need these parts!
    SE-i Sedan 5 spd
    I'm having that problem myself, which seems to vary with temperature. Very cold or very hot, strangely. My mechanic said (last summer) that it's the lower ball joint, but the joint itself is not worn out. I definitely have to get on top of it soon, or the temperature has to get warmer, it's very disconcerting.
    carotman's Avatar
    Don't leave this one unattended!
    What happend most of the time is that either is lacks grease or water got in and it started to rust inside.
    There's 2 things that can happen. The joint will seize from time to time. Once you turn the wheels, the stud will get weaker from the torsion and will actually break someway. If it doesn't seize, it will just wear and wear over time and could pop out.
    Both outcomes are the same. The wheel will come in contact with the inner fender, causing a mess, possibly breaking the brake line and popping the CV joint out. Might also bend the fender...
    It's going to look like this:
    For some obscure reason, this happens mostly at low speeds where you turn more your wheels.
    I need these parts!
    yeah its been getting louder so i want to get it taken care of. so lower ball joint eh
    Frantik
    Did you take care of this yet?
    You know I have time now on weekends to help you out if you havent fixed it yet
    give me a call if you need some help
    LX User 3rd Party's Avatar
    Jan 2009
    1987 Honda Accord LX-i (4dr)
    Boise, ID
    what about clicking once the wheel has been turned more than 60*??
    1987 Honda Accord LX-i (A20A3) (179k)
    79-whp, 103-wtq (Performance Solutions)
    "...if you type, 'Google' into Google you'll break the internet..."
    SEi User codyJDM's Avatar
    Apr 2008
    '88 civic wagon
    SoCal
    Quote Originally Posted by 3rd Party View Post
    Axles.
    Frantik
    not yet.. i need to a) find out what is wrong and b) have money to buy the replacement part
    i'll have u guys look at tomorrow if possible so i know what part to get
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    the squeaking sounds more like control arm bushings too me, but if you do the upper joint too this wont be a problem.
    Went to the picoshop and replaced my outer tie rods today, it solved the noise problem and made my suspension feel so much better
    Dec 2008
    honda accord se-i coupe
    nice u got it solved
    is soo annoying the noise it makes/
    i greased my joints with white lithium grease and wooaaalaa
    Ball Joints and prelude arms next...
    w00t sounds good
    thanks again dude.. you did those tie rods before i could even blink
    SE-i Sedan 5 spd
    I've been wondering about my tie rod ends, as I have 217k. Can you tell when the car's up on the lift that the ends are worn? How many miles are on yours? Or did you just take a shot and it paid off?
    LX User LxAcc510's Avatar
    May 2008
    1989 Honda Accord LX
    Where they say Hella, CA
    I need to get on top of this too. My car sounds like a squeaky matress too =X
    '89 LX 295,000 3/1/09 =D
    Quote Originally Posted by w261w261 View Post
    the original plan was to replace frantik's ball joints, when I got started I noticed that his outer tie rod boot was torn badly.
    I inspected the ball joints for play and there wasnt any, so we decided to just replace the tie rods for now since that was really needed and there was play in the steering from left to right. ( the socket was ready to pop out of place ) we're doing his ball joints next and replacing his l/f axle at the same time since he has a torn boot on the outer joint.
    Quote Originally Posted by LxAcc510 View Post
    I need to get on top of this too. My car sounds like a squeaky mattress too =X
    time for bushings and more to get done.
    w00t sounds good
    You're going to get it aligned now right?
    Might as well get all the ball joints replaced and then go for an alignment.
    as pico said, the boot was torn.. you easily see it when the wheel was off but you can probably inspect them if you turn the wheels all the way to one side without putting it on the lift
    the new tie rod ends barely moved at all in the socket while the old ones could be moved easily with one finger. I suspect they were original with the car (so 220k miles on them)
    the ends were only $25 for the pair and pico managed to swap them in like 30 mins tops so if you've got any doubts just go ahead and replace them
    i'm planning on doing more suspension work soon so i'll probably wait. Plus my house is over an hour away from Picos and i didn't have any alignment issues on the way home so i might skip it anyways
  1. Front Bumper Apron "Holder"
    By Hirst in forum 1geez Accords
    Last Post: 11-13-2009, 02:05 PM
  2. Is your lowered car's front end to high? Here's a fix to drop the front 1/2"
    By Jims 86LXI HB in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-01-2008, 02:16 AM
  3. Directed to anyone who bought Mike's89AccordLX "custom front strut bar"
    By Busted_Blue in forum Classic Honda Community Chat
    Last Post: 09-12-2004, 11:47 PM
  4. FS: Tan/Beige front "tape" console
    By markmdz89hatch in forum Trading Post
    Last Post: 03-22-2004, 06:39 AM
  5. 2.5" front drop + 1.5" rear = unbalanced car?
    By MoonScryer in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-21-2002, 12:13 AM
