Page 2 of 2 FirstFirst 12
Results 26 to 38 of 38
Thread: loud "spring" noise front front
    Re: loud "spring" noise front front
    i need to replace mine too.
    might get some tomorrow
    my ball joints are still tight but when i popped the lowers out when i did the trans both boots deteriorated
    the ends were only $25 for the pair and pico managed to swap them in like 30 mins tops so if you've got any doubts just go ahead and replace them
    were did u get them from?
    napa i think.. they were $12 each, moog parts in a napa branded box iirc
    i'm planning on doing more suspension work soon so i'll probably wait. Plus my house is over an hour away from Picos and i didn't have any alignment issues on the way home so i might skip it anyways
    Your only alignment issue could be that you burn up the tires in 3,000 miles. Did you at least do a poor man's alignment? You can measure the distance between the front of the tires and the rear and make sure that there isn't any difference. If you have a lot of tow, you might be in for a new set of tires a lot sooner than you want.
    my camber eats tires for breakfast luckily there's a cheap used tire place near me lol
    i don't drive a lot so it's ok for now but once i finish rebuilding my suspension and some camber kits, I'm going to get an alignment and a set of good new tires
    I set the tie rods back to the same spot as the old ones.
    I loosend the lock nut and carefully unthreaded the old ones and carefully rethreaded the new ones on, making sure not to disturb the position of the lock nut.
    So he'll be good till he gets his alignment done
    thats why pico is the man
  8. #33
    Its easy to change the tie rod ends. I remember changing the rack and pinion and somehow the measurements were different from stock. My alignment was way off. I spent 8 hours in the damn heat doing the swap and still had to go to work driving the car on the freeway with the wheel cocked to the left almost 1/4th to 1/2 of a turn.
  9. #34
    Agreed. Pico is the man. I do the same, but I've found the poor man's alignment to be more accurate. There are so many manufacturers of replacement tie rods out there, you can be careful and still be off by light years because the housing on the new one is completely different from the housing on the old one.
    Anyway, I'll get off my soapbox now. I'm glad you were able to get it all done and working great.
  10. #35
    lol.. word.. i will get an alignment as soon as we do my axle and ball joints, don't worry
  11. #36
    3g with broken tie rod
  12. #37
    WHOA....damn....easyest way to replace one is to mark the inner tie rod end with whiteout and count how many times you turned it to get it off.. I did that and i was 1/36 off on the alignment rack...i get free alignments so that trick always works...
    yeah good job...for me suspension needs to be good specially on a lowered car.
  1. Front Bumper Apron "Holder"
    By Hirst in forum 1geez Accords
    Last Post: 11-13-2009, 02:05 PM
  2. Is your lowered car's front end to high? Here's a fix to drop the front 1/2"
    By Jims 86LXI HB in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-01-2008, 02:16 AM
  3. Directed to anyone who bought Mike's89AccordLX "custom front strut bar"
    By Busted_Blue in forum Classic Honda Community Chat
    Last Post: 09-12-2004, 11:47 PM
  4. FS: Tan/Beige front "tape" console
    By markmdz89hatch in forum Trading Post
    Last Post: 03-22-2004, 06:39 AM
  5. 2.5" front drop + 1.5" rear = unbalanced car?
    By MoonScryer in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-21-2002, 12:13 AM
