Results 1 to 4 of 4
Thread: Idle reving. . till warmed up
    LXi User -$MOKIN-'s Avatar
    Apr 2006
    1989 HONDA ACCORD LXI
    What do i need to replace from a efi rev fluctuation?
    Re: Idle reving. . till warmed up
    Check your coolant level and check for vac leaks.
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Also see that idle is set to specified rpm. Increasing your idle to compensate for worn motor mounts (we've all been there) too much will cause a fluctuating idle.
    CARDONE SUCKS.
    LXi User Vector's Avatar
    88 Accord DX-RWD
    Kelowna BC
    another thing, the cold idle air valve behind the tb towards the firewall, i took the 2 screws off and the little lid and screwd the plastic valve back in.. other than that, also what dr snooze siad.
    check the vac advance pods in the distributor also. if they are leaky they can cause irratic idle due to incorrect timing and vacuum loss. i've had to replace a couple on higher mileage 3g's.
  1. not reving up fully after idle
    By petey882 in forum 3geez Accords
    Last Post: 05-18-2009, 03:45 AM
  2. Idle trouble after warmed up
    By leem in forum Carburetor Tech
    Last Post: 07-19-2007, 08:10 AM
  3. idle control? weird reving
    By hornster247365 in forum 3geez Accords
    Last Post: 05-08-2007, 09:05 PM
  4. Warmed Up = More Power
    By HondaBoy in forum 3geez Accords
    Last Post: 01-27-2005, 09:21 PM
  5. rough & wierd idle after engine fully warmed
    By wolfort in forum 3geez Accords
    Last Post: 03-21-2004, 10:21 PM
