Page 2 of 2 FirstFirst 12
Results 26 to 45 of 45
Thread: LSD for 3rd gen Accord ............YES???
    S.Glastonbury, CT
    Re: LSD for 3rd gen Accord ............YES???
    I have yet to play with my gear ratio's but i am sure there are gears out there that will swap. My B20A gears are to short for a boosted car so i want to work on that.
    SEi User turabaka's Avatar
    Aug 2007
    Boise, ID
    Not sure if I just missed it or what, but are those diffs a one-way or two-way limited slip?
    On a side note. Any thoughts on who makes the best one-way clutch style limited slip? Nobody had better say Phantom Grip.
    Ichiban's Avatar
    North of You.
    I'm interested in the Quaife, torsen, detroit truetrac etc.... diff for these cars. I do need to regear my box in the worst way though.
    ICHIBAN!
    "Now, even more better!"
    i was also thinking that but also the output shaft would have to match up the final drive...and no output shaft is 19 spine count like ours with a 212mm disk because the b series disk are 220mm with 24 spine count
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Thanks for the input messy. I guess the optimum configuration (after about an hour playing with gear calculators and doing research) is 1-4 teg and 5th accord, with the teg final drive. Something we already knew lol. What a waste...
    '89 SE-i Coupe
    Awaiting Garage
    lsd would also help too...
    only reason i want a LSD is cause its a easy way to get rid of the diff pin that snaps and fucks your whole box issue haha
  8. #33
    May 2004
    Yeah, yeah, just so we're clear -
    A B series LSD will fit into an A20 series differential?
  9. #34
    Apr 2004
    '87 Accord LX-i/'85 Toyota Supra
    Will this work for an automatic as well?
    OBX has LSDs, anybody know how good they are?
    '87 accord lx-I sedan: Koni adj, struts, Progress sport springs, ST sway bars, spec. prod. camber kits, dc strut bar, msd blaster 2 coil, ngk plugs and Ractive 9mm wires. Erebuni bodykit and Wings West trunk spoiler.
  10. #35
    auto diffs are completely different i think but theres bound to be one made for a auto b series that might fit?
  11. #36
    Apr 2004
    What about the Phantom Grip ones? Will they work with my automatic?
  12. #37
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    No
  13. #38
    Apr 2004
    There's gotta be something out there I can use......
  14. #39
    Quote Originally Posted by ACE_14 View Post
    yea only way is to convert to 5 speed
    Apr 2004
    REALLY?.........
    There's all sorts of Automatics out there with LSDs and your saying there's nothing for our Accords.
  16. #41
    why bother with an auto? I smoked mine running 17s in the 1/4... then i swapped to 5 speed and dropped over a second alone just by rocking the 5 speed. So a 5 speed swap is a must if your going for performance in this car
  17. #42
    LX User 1813mdw's Avatar
    Nov 2010
    Jackson, Michigan
    REALLY?.........
    your best bet would be to contact a few lsd companies and ask them yourself. phantomgrip has put lsds in everything from vintage racecars to pt cruisers, so give them a call.
  18. #43
    its because no one bothers with an auto when it comes to racing, as AccordEpicenter said, he dropped 1 second off his 1/4 which quite a bit.
    best bet after talking to some LSD companies would be to try a automatic b series diff in your auto accord box, if its fits, find a b series auto box thats LSD and swap the diff.
    auto LSD b series cars do exist (from japan)
  19. #44
    Apr 2004
    Well I'm waiting for a reply from Phantom Grip, so lets see what they say.
    Everybody gives up on an Auto, I'm not going to. This isn't going to be an all out 10sec. racer. I'm keeping it as a DD, but I would love it to handle more power when I need it to.
    I've already got my Raybestos Stage-1 Frictions and Steels, along with a complete overhaul kit that I bought from, What Ever It Takes. My mechanic's just waiting for me to drop it off. While everything is apart I'd like to take the chance and put in an LSD if possible.
    It should handle what I have planned for my car with no problems.
  20. #45
    Nov 2010
    Jackson, Michigan
    i personally would prefer a 5speed but props to you for not following everyones footsteps. if you want an auto go for it. you might have to blaze a couple trails; but in the end you'll have what YOU want. good luck, bud. keep us posted
