Results 1 to 25 of 45
Thread: LSD for 3rd gen Accord ............YES???
    Accord of the Year - 2006
    guaynabo89's Avatar
    FL
    Well guys a long time ago I sent out a differential to Quaife LSD's to see if anything they made was the same as the Accord diff. Well the person I had sent it too shortly after got terminated and I never recieved a response from them. About a week ago I received a call from someone at quaife asking if I still was looking because it had been sitting at this persons desk for over a year with all my info still attached. I said sure why not. They told me they had a new model called the wavetrac lsd and they were going to check that one. Well the next day they called me and said they had verified that it was the same size as the B16 diff. Same bearing size, same spline axles, but the only thing different was the speedo gear so that would need to be swapped out.
    Now understand they i cannot verify this as my transmission was put back together long ago. If the people over there are as skilled as they should be then it should be ok.
    The company that owns Quaife LSD is here:
    http://www.autotech.com/index.htm
    The diff site can be found here:
    http://www.wavetrac.net/index.htm
    The part number you are looking for is:
    60.309.160.wk
    and thats for the B16.
    If anyone chooses to go this route ask for Ryan at the autotech contact numbers site. Tell them Dennis with the old 87 Accord had sent in a diff to be compared and they they said it would bolt up and only a swap of the ring gear is needed.
    Another thing is that this might mean that any B16 lsd from any company would fit, not just theirs. Again I cannot verify this so please plan accordingly. I know not many people on this site would need or spend the money on this thing but like always.... I pass around the good info.
    Oct 2000
    '88 Accord LX-i
    Connecticut
    Re: LSD for 3rd gen Accord ............YES???
    good job dennis! is there a difference between the hydro and cable b16s? if not then you should be able to use an OEM type-R diff as well
    '88 LX-i Coupe --- LS/Vtec
    hope it works for the integera hybrid tranny also
    guaynabo89's Avatar
    FL
    It is the same diferential in the 86-89 tegs so yeah it should be good.
    I dont know much about the b16 trannies but being there not listed as hydro or cable on their site they are probably the same.
    Oct 2000
    '88 Accord LX-i
    Connecticut
    time for you to pick up a LSD! I guess I shouldn't be too surprised because rob is using a b16 lsd in his b20 trans
    Vanilla Sky's Avatar
    1999 Penalty Box
    When I build my teg hybrid, I'll be getting one.
    guaynabo89's Avatar
    FL
    It would have been nice if I would have had that info a year and a half agon when the tranny was apart and out of the car. Unless something breaks or I feel like getting my brother in law to drop it again I probably wont be using one.
    how are the prices?.....im going to rebuild another trans for my b20
    guaynabo89's Avatar
    FL
    they list on their site for like 790 but you could probably get it somewhere else cheaper.
    Only nice thing is that its off the shelf. No waiting while you send in a diff to get modded.
    I need one for my new tranny build...my stock on taking a poo...main bearing making sounds again lol after a year of replacing it.
    so this means the a20 diff is the same as the b20 one sicne the b16 LSD also fits the b20a, No wonder b20a boxes blow diffs all the time...
    S.Glastonbury, CT
    I have had the Quaife LSD in my accord B20A since 2005 and its from a 99+ B16A just for clarification for the B20A guys that posted here.
    And all i did was put my new JDM B20A bearings on it and the speed sensor gear and dropped it right in with no issues!
    I vote sticky! if i ever pull my tranny apart again ill be putting a lsd in!
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    just posting so i am subscribed. this is a great idea. if this works we will all have obx diff's! heheh
    LX User fogged's Avatar
    Jul 2007
    89 LXi Coupe 5spd
    Olathe Ks.
    An LSD for the 3g.... Hell yeah.
    Ichiban's Avatar
    North of You.
    Quote Originally Posted by RobT5580 View Post
    I always new there was something out there that interchanged. How is the speedo gear attached, just pressed on?
    ICHIBAN!
    "Now, even more better!"
    Yeah if only they were easy to find!.. And cheap
    Feb 2004
    89 accord lxi
    down by the bay
    Quote Originally Posted by guyhatesmycar View Post
    it's just held in with a clip ring, but i think you might have to pull the bearing first to get to it.
    Feb 2004
    89 accord lxi
    down by the bay
    Are you saying the teg diff is the same as the b16, or the accord?
    I never compared the teg diff with the accord...
    Quote Originally Posted by Strugglebucket View Post
    they should be the same cuz i used the outer final gear on my accord diff
    S.Glastonbury, CT
    Its just pressed on and it was an easy swap out with the right tools of course. I would not recommend doing it for less experienced people but overall the hardest part is getting the clip that hold the bell housing in place off and back on again.
    Quaife LSD is one of the best. This in itself lends me to work with an A20 and not go B or H22 route. There expensive but well made.
    SEi User
    Jan 2004
    LSD i can confirm it works there was a Honda enthusiast who built a 3rd gen civic called Kakkbox for autocross custom everything the guy was a machining god!! He dropped a D16 from a teg into it like the JDM cars had and after some research he found that yes the 99-00 Civic SI B16 LSD does fit but depending on which brand LSD you may need to get your dremel out and file a bit of the inside of the casing down to clear the bolt heads on the LSD. This was done with out issue, he also noted not to go with the cheaper brand LSD's but spend the money and buy the more expensive Quaife or similar brands you pays for what you get kinda attitude as i think he had stuffed a cheaper one up quite easily. So yes will fit Teg box and Accord box plus late 2nd gen lude boxes early ones are maybe a no no.
    Jan 2003
    1986 prelude
    charlotte nc
    well this fit my b20 tranny also , how much was this aslo does the cusco lsd work as well
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Sorry to dig this thread up from the grave, but for clarification, this would mean that the final drive gears from B16A's, A20's, B20A's and B18B's should all go in without any problems?
    '89 SE-i Coupe
    Awaiting Garage
