Results 1 to 25 of 43
Thread: 4g MAP sensor myth debunked
    cygnus x-1's Avatar
    Chicago area
    So after reading about the supposed benefits of the 4g MAP sensor I decided to do a test of my own to see what the deal really is with these things.
    So I took 3 sensors, a 3g (PS10), a 4g (PS20), and another one (PS22) that I think came out of an early '90s Integra or some other OBD1 Honda. The 3 sensors were all connected to a regulated 5V benchtop power supply and were measured with an HP benchtop multimeter. A hand vacuum pump was used to vary the pressure to all the sensors.
    Here are the results:
    Code:
    Pressure (inHg)        PS10 (V)        PS20 (V)        PS22 (V)
    0                      2.88            2.87            2.87
    5                      2.42            2.41            2.41
    10                     1.92            1.92            1.92
    15                     1.47            1.46            1.46
    20                     1.01            1.00            1.00
    25                     0.52            0.51            0.52
    At each pressure the 3 sensors read almost identically with a worst case error of 2% at 25 inHg. Given these results I would have to say there will be no measurable difference in performance when using any of them.
    C|
    Ichiban's Avatar
    North of You.
    Re: 4g MAP sensor myth debunked
    I figured as much. As far as people saying that they got mixture enrichment or a 1-2 MPG loss with the 4g map sensor, well, this:
    1. The o2 sensor will detect any rich mixture condition, and the ECU will compensate by shortening pulse width
    2. A 1-2 MPG loss is virtually impossible to detect without exacting testing conditions and sensitive equipment.
    ICHIBAN!
    "Now, even more better!"
    wierd....I dont know but i just felt a difference. and yet messy had dyno results that proven that he had hp gains. Well thats good to know bout the map sensor myth
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    yep. i have always felt that a 1bar map = 1bar map = 1bar map.
    lol... nice looking out though. good to see my suspicions confirmed as well...
    Yea, me and mushroom told u guys it didnt help. His dyno run he swapped out sensors, and all the other ones did was richen the fuel some. no extra power, tq curve was Super lightly affected, but no real gains.
    I'm think you might have caused a code in your ECU and "default rich" which in your case helped your set up. I mentioned this a few times before,way in the past, but was quickly shot down.
    cyg thats a great way to test a sensor, great work !
    ummm i dont thinks so bro...When i put my stock one back it i was like wtf...i notice it on top end. Works even better now when boosted. If i use my stock map i get a code..4gen map no code. Watever it worked for me. im not shooting you down bro. i know what it did and how it performed. Its just wierd. Results are results they dont lie...maybe its justs me.
    are you sure your stock one wasn't bad? all these do is produce a certain voltage depending on bar, the computer doesn't know the difference, if it has the same voltage to bar curve, it works the same. it would seem like your stock one might have been going thats why it threw a code probably also.
    You west coast flip flopped there which is it ?--------------------------------------------------------------------------------
    wierd....I dont know but i just felt a differance. and yet messy had dyno results that proven that he had hp gains. Well thats good to know bout the map sensor myth
    End quote:
    so its a myth, but it works for you, but im wrong, it doesn't work?
    I'm not buying anything so you can be straight with me.
    End quote:
    i'm thinking if these were swapped for stock sensors, after all these years the stock sensors were probably out of calibration. if you drive a car with one thats going and isn't throwing a code, you get used to it, if you replace it with a new one,of course you would feel the difference.
    End quote:
    stock map worked fine or maybe it was bad....wtf is west coast flip........you like my periods lol......................Anyways The only reason i got CEL was under BOOST on my stock my with the 4gen map i DID NOT GET CEL. but it made a difference for me. so
    LX User 3rd Party's Avatar
    Jan 2009
    1987 Honda Accord LX-i (4dr)
    Boise, ID
    Quote Originally Posted by cygnus x-1 View Post
    0 2.88 2.87 2.87
    5 2.42 2.41 2.41
    10 1.92 1.92 1.92
    15 1.47 1.46 1.46
    20 1.01 1.00 1.00
    25 0.52 0.51 0.52
    C|
    haha, thank you cygnus! all i have to say is, "BURN!!"
    1987 Honda Accord LX-i (A20A3) (179k)
    79-whp, 103-wtq (Performance Solutions)
    "...if you type, 'Google' into Google you'll break the internet..."
    had a feeling they were all the same
    cygnus x-1's Avatar
    Chicago area
    One thing I should point out is that this still doesn't explain why Honda felt it necessary to change the MAP sensors. There is obviously *something* different about them otherwise why would they bother? It could be a number of things though; updated internal circuitry due to manufacturing changes, wider measurement range, better accuracy, reduced temperature sensitivity, better/different dynamic response, reduced electrical noise, etc. All of these things could apply and still not affect the static pressure vs. voltage curve.
    As for dyno runs; (chassis) dynos aren't nearly as reliable as most people think they are. There are SO many variables that affect the numbers you will see on a dyno that it's very difficult to get consistent results. To really prove that a particular part has an effect you would need to make several runs with and without that part and average each set of results. You would also need to make sure that on average the engine was operating under as close to the same conditions as possible. Even a few degrees difference in coolant or air temperature could affect the results. And ideally you would want to look at the standard deviation for each set of numbers as well to make sure the data sets have at least similar variability.
    Rendon also mentioned boost. Boost is an entirely different game. None of these sensors (the ones I tested anyway) are designed for much more than standard atmospheric pressure (I presume) so once you get into that realm all bets are off. But now that I think about it I suppose I could test them again with positive pressures and see how they do.
    In fact I think I'll do just that.
    C|
    Thanks....Why is that with a stock map sensor i get CEL with the 4gen map i get nothing at 10psi. What do you me i need to get into REALM? Im not beening nagative with nothing. I just felt a difference with or without stats. BUT I like how you took your time to see how the differences are. Would like to see how you test em on positive pressure...I assuming should be good for the fact i dont CEL
    Jan 2009
    Boise, ID
    C|
    i'm assuming they changed MAP sensors 'cause the motor was obviously changed, along with the ignition system. as we all know, 4th gen Accords are OBD1, and we're OBD0, so i'm assuming the MAP sensors were changed for the new OBD shindig?
    cygnus x-1's Avatar
    Chicago area
    That's exactly what I'm saying. The test I just did was only with vacuum and doesn't apply under boost. Given what you've experienced I'm guessing that the sensors do act differently under boost. 10PSI happens to be +20inHg, which if the sensor curves are linear would be right at the edge of their maximum pressure capability.
    It will be interesting to see what happens. I'll try it tonight.
    C|
    I already had it posted that these dont do anything in my dyno thread. lol.
    bobafett's Avatar
    Longview, WA
    I don't recall the details, but that does correspond with real world experience and everything I have read up at hmt, if you run more than 10-11psi, you must use either check valves to limit that amount of boost that your map sensor sees, or you need to upgrade to a 2,3, or 4 bar map sensor so that it can read boost and still give an accurate reading.
    Nafs Asdf's Avatar
    Feb 2008
    Finland
    Wouldn't a 1 bar sensor read up to 14.5 psi?
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    a 1 bar sensor will read up to 1 bar absolute which is atmo
    need a 2 bar sensor to read up to 14.5 psi boost which is 2 bar absolute
    the model changes could be cause of anything, the biggest thing i can think of is one has wires coming out, one had a plug directly on it and the other mounts to the TB but there could be a lot of other revisions too.
    Quote Originally Posted by 3rd Party View Post
    we are actually obd1, except for the carbs, the FI had diagnostics and trouble codes and a check engine light. even the prelude dual carb models were obd1, they had onboard diagnostics, they even had a mass airflow sensor on some of them and a map sensor.
    AZ
    it may have had the diagnostics but it's not obd1 lost, not at all.
    dead white and blue
    'A20A3''s Avatar
    Mar 2003
    '89 LXi Coupe
    eastern shore, MD
    hmmm. maybe i'm crazy. but i know it made my top-end better...
    -Harvey
  1. Backpressure vs burnt valves myth
    By POS carb in forum 3geez Accords
    Last Post: 12-08-2012, 09:39 PM
  2. Coolant temp sensor tw sensor
    By Bluntman in forum 3geez Accords
    Last Post: 07-06-2009, 06:12 PM
  3. Help me solve this dilemma/myth, neutral or gear?
    By Mario Calero in forum 3geez Accords
    Last Post: 03-27-2006, 06:50 PM
  4. Need help! Broke a sensor wire (green sensor)
    By SMaurer32 in forum EFI Tech
    Last Post: 10-31-2005, 08:06 AM
  5. Sub myth?
    By MrBen in forum Interior & Exterior Care
    Last Post: 01-16-2004, 01:21 PM
