Results 1 to 13 of 13
Thread: how to fight front bumper sag?
    well one day i was driving to a parkinglot and it was too low so i hit the front bumper on it and now it looks like it sags alot more than it did so i need what do i have to replace...i tried looking online for the bushings but i could not find them.
    Re: how to fight front bumper sag?
    you may be able to add some sort of shim/washer to help support the rubber mounts on the bumper
    the bumper sag i usually get is at the front, and i found out that its caused by not putting those annoying bolts in underneath that bold to the front crossmember lol
    i would like me a usdm bumper, the plastic part anyway. jdm bumpers are warpage galore
    i have sag on the right front. its wierd. Im going to have to add shims like you guys said
    i just jack the car up set something under the bumper support(like 5 inchs lower then the car is jacked up) like a couple bricks or a jack stand and then drop the jack down fast and it bends the support up wards and fixs the gay sag
    SEi User 86ccord's Avatar
    Middle Georgia USA
    oh ok.. what about those who are too low and cant use a jack?? HUH? LOL
    ( Note to self.. buy a special jack.. )
    one day I'll return.
    it's not the bumper thats sagging and dropping the car on the bumper is not a solution, unless you are into things like sticking drywall screws through the bumper ends to hold it up. the problem is the rubber pieces inside of the square bumper mounts. what you need to do is take a mount to the hardware store, find a large steel washer you can fit into the top and bottom of the rubber mount part where the bolt goes through it,works like a charm and makes the mounts almost solid.
    you jack it up with a scissor jack until u can fit a regular one under losts idea sounds better though lol
    jack it up using the front tow hook in the middle.
    or, keep a block of wood in ur car so u can roll it onto there and get a normal jack under(i have 2 blocks in my car lol)
    it's very easy to remove those bumper brackets from the car and fix them the correct way.
    Thats what I told him to do in a indirect way.
    Oct 2000
    '88 Accord LX-i
    Connecticut
    '88 LX-i Coupe --- LS/Vtec
  1. 88-89 bumper lights mount up to 87 front bumper?
    By mike5721947 in forum Interior & Exterior Care
    Last Post: 03-19-2007, 06:05 PM
  2. 2g teg front bumper and 4g cord rear bumper?
    By slow87LX in forum Interior & Exterior Care
    Last Post: 04-14-2005, 07:07 PM
  3. Fire Hydrant Fight, Accord wins
    By kaymo in forum Classic Honda Community Chat
    Last Post: 02-06-2005, 07:40 AM
  4. Aerodeck front bumper vs. US front bumper
    By shepherd79 in forum Interior & Exterior Care
    Last Post: 03-01-2003, 10:44 AM
  5. Front Bumper
    By 87_2LSi_au in forum Classic Honda Community Chat
    Last Post: 08-21-2002, 05:18 PM
