Results 1 to 18 of 18
Thread: running rich?
    LX User accordion89's Avatar
    1989 ACCORD LX
    Seattle
    Question running rich?
    It kills me to see the time some put into their cars before driving, theres one thread about a 380 dollar ebay car thats inspriring, I'm having problems with my car smoking out the tail pipe, looking at the smoke its not blue colored or smokes downhill, its grey at start ups and clouds up and goes away
    I know I have to adjust my valve height, not mechanical, but any ideas?
    I still drive my car even with this problem, I go to shool full-time and seattle weather impedes my automotive time cause I live in an apartment and dont want my apt manager questioning me
    Oh you guys were very helpful about my torn fuel line, I fixed that, very easy
    1989 ACCORD LX
    Seattle
    Re: running rich?
    * I'm not mechanical, rather
    Re: running rich?
    It smokes on startup? But goes away after a while? That sounds like either you've got a valve stem seal leak if it's black smoke, or if it's just steam, that's just a cold engine and it's normal. Especailly here in our climate, my cars always puff out steam in the morning. If it goes away after a few minutes, I wouldn't worry about it too much. Maybe give it a whiff, it also should be a little rich when it's cold, it helps with cold starting, it's caused by the choke being closed.
    If you're looking to do a valve adjust, I recommend picking up a Chiltons or Haynes. Even better would be a factory Honda manual. It's a sort of detailed process, but isn't really hard.
    1989 ACCORD LX
    Seattle
    Re: running rich?
    oh yeah, valves I'm not to worried about, the weather is a deturent
    its a grey smoke, but I dont think its because of the cold weather,
    lol, I'm taking a final right now
    Re: running rich?
    Does the car run rough when you first start it up?
    1989 ACCORD LX
    Seattle
    Re: running rich?
    what do you meen by rough, not that I've noticed, i give it a little gas when starting
    i had a problem with the motor deisling after turn off, but it hasnt done it since i replace my fuel filter, not sure if that fixed the problem, but it runs a little better
    1989 ACCORD LX
    Seattle
    Re: running rich?
    lol, I just finished one of my finals, think I aced it
    Re: running rich?
    Good work on the final.
    Dieseling, I believe, is a sign of running lean.
    1989 ACCORD LX
    Seattle
    Re: running rich?
    Hmmm, my thinkings backwards, I will have to read up on it
    not afraid to work on my car, just if I'm lacking in knowledge
    I was having a problem with the idle raising up to about 2900, not eraticly, but on initial take off, if i would shut off it would deisle, and would not fire up when trying to start, I was thinking fuel problem, my filter looked as if it was never replaced, so I replaced it and the hose attached (tore when taking filter off :/ )
    Re: running rich?
    Oooh I see. Well if you shut the engine off while the revs are high, the throttle plates stay open a bit, while the fuel supply cuts, hence a lean condition at shutdown.
    Definitely replace BOTH fuel filters. Hmm I am pretty sure the 3gee also has 2 fuel filters, that might just be the 2gee. Well replace whatever amount of filters you have.
    The problem with the high idle is probably related to one of your thermovalves. It basically controls vacuum to the high idle solenoid based on temperature of the coolant. It's supposed to keep the idle up while the engine is cold. Sounds like that it going haywire, or perhaps the solenoid itself is sticking, and a little WD40 could fix it.
    Re: running rich?
    The reason I ask if its running rough is because if your choke does not operate properly it will make the car rich. I know it did in mine.
    1989 ACCORD LX
    Seattle
    Re: running rich?
    the only time it is rough is when putting in drive at startup if the idle doesnt drop
    Re: running rich?
    Hmm, well let us know if you find anything out. Check out the choke and make sure it's closed when the car is off, and opens up after the car is running again.
    1989 ACCORD LX
    Seattle
    Re: running rich?
    ok, I have a haynes manual, thanks for pointing me into some directions
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    Re: running rich?
    run on/diesiling can be caused by the lean mixture mentioned before, incorrect ign timing, build up of carbon in the combustion chamber or even a spark plug thats of to high of a heat range.
    i think carb 3g has two fuel filters, ones right at the back of the car somewhere.
    1989 ACCORD LX
    Seattle
    Re: running rich?
    there are two filters, ones up by the carb, I havent replaced that yet, havnt found time to do it, I'm going to try to do as much as I can in the engine bay when I can
    1989 ACCORD LX
    Seattle
    Re: running rich?
    there are two filters, ones up by the carb, I havent replaced that yet, havnt found time to do it, I'm going to try to do as much as I can in the engine bay when I can,
    I replaced the lower filter by the tank/left travel arm of the car along with the hoses, I was surprised how much a shop in washington charges to do this, jiffy dudes charge like 70 to do it w/o the hoses, I paid like $4 for the filter and $6 for the hoses
    Re: running rich?
    When you replace the hose under the hood replace the lines a well. Cheap insurance.
  1. Running rich/Flooding?
    By 89fuelie in forum EFI Tech
    Last Post: 01-15-2012, 07:43 PM
  2. Running Rich
    By barber107 in forum 3geez Accords
    Last Post: 11-25-2004, 12:19 PM
  3. Running Too Rich
    By Janiel in forum 3geez Accords
    Last Post: 06-14-2003, 09:57 PM
  4. Running Rich
    By 1987HondaAccord in forum EFI Tech
    Last Post: 01-10-2003, 01:35 PM
  5. Running rich in the wet?
    By 89AccordNate in forum 3geez Accords
    Last Post: 12-12-2002, 08:04 PM
