Results 1 to 22 of 22
Thread: i need help
    LX User fijisac's Avatar
    Feb 2009
    1989 honda accord LX
    sacramento, california. 91sickness
    Unhappy i need help
    well i had a blown head gasket 3 weeks back. i replaces the gasket and i got the head rebuilt for $260 with new seals, springs, and valves. so i put the motor back together and when i started it up, there was a big cloud of white/light blue smoke coming out the exhaust pipe so i waited for 5 minutes to see if it would go away and it did not, so what can be the problem?
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    Re: i need help
    id check the timing belt and make sure its installed properly. 3or 4 teeth out and it could run bad... does it make any ticking sounds or anything?
    Re: i need help
    light blue smoke sounds like oil burning
    Feb 2009
    Re: i need help
    well it does run rough after 3000 RPM but before 3000 Rpm it runs fine
    Feb 2009
    Re: i need help
    well that's what i thought but the oil level was still the same after i drove it
    Re: i need help
    did you change the oil after the headgasket job?
    PVC system intact?
    retorque the head?
    LX User mephi's Avatar
    Apr 2004
    1987 Accord DX 4 door
    Port Orchard, WA
    Re: i need help
    Make sure the timing is set properly, and then run a compression test.
    Feb 2009
    Re: i need help
    PVC system intact?
    retorque the head?
    well ok i did change the oil and re torqued the head but i need help with the PVC system cause i have no idea what that is
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    Re: i need help
    yea, id do a comp test on it too...
    Re: i need help
    How about you just drive the car for a bit? You just changed the head gasket. I would not be surprised if theres still water in the exhaust that is burning off.
    Re: i need help
    yeah what he said, when i took the exhuast off my dx (parts car that had a blown head gasket ) and put it on my lxi the car smoked like fuck for atleast a hours worth of driving time
    Re: i need help
    its a blown gasket. idk what you could of done wrong. Maybe over tighen the head gasket. did you torque to specs.
    Head bolts are:
    Step 1:22 ft-lbs
    Step 2:29 ft-lbs
    If you didnt do that then thats your problem
    Feb 2009
    Re: i need help
    Head bolts are:
    Step 1:22 ft-lbs
    Step 2:29 ft-lbs
    well no i torqued it to
    Step 1:22 Ft-lbs
    Step 2:49 Ft-lbs
    Feb 2009
    Re: i need help
    really, i did not know that, thx
    Re: i need help
    Quote Originally Posted by fijisac View Post
    Step 1:22 Ft-lbs
    Step 2:49 Ft-lbs
    I meant that LOL...
    Feb 2009
    Re: i need help
    I meant that LOL...
    but yea, thats what i did, by the way do you know where i can get a complete vacuum diagram for a 89 accord carb
    Re: i need help
    Pauls web site. has service manual downloads. LEt me go get it real quick
    Re: i need help
    Feb 2009
    Thumbs up Re: i need help
    thx man ur a big help and oh by the way do u know where the PCV or PVC valve is located
    Re: i need help
    Right inbetween the runners. so ()()HERE()() you'll see a tube with a piece of foam pretty much. And its a metal valve. no plastic
    Feb 2009
    Smile Re: i need help
    alright thx
    Re: i need help
    No prob. that manual well tell you everything bro.
