Ok the PS cooler is in, this is out of a ford,it's a factory engine oil cooler, these things were a major problem on ford cars,because the passages were too small for engine oil, and they sludged up. you can get these for practically nothing at junkyards. the main thing is you need to clean out all the gunked up oil from the ford engine. i filled it full of solvent, then hooked an air line too it and let air run through it, kept doing this and after a couple of hours,it popped and all the crap blew out the outlet. good idea to hook another hose to the outlet and put it in a can or something. I think it will be just fine for PS fluid, it's not full of the combustion byproducts that cause sludge to form. this would actually work as eithier a ps cooler or a transmission cooler. all i had to do to make it fit, was cut off some of the extra tabs on the mounting with shears, then make one small mounting block to space it back towards the radiator. i don't have ac anymore,so it fits really nicely in the space in front of the radiator. the metal pipes are stock ford, and they fit perfectly into the hole for the PS hoses. look like they were supposed to be there. you have the option to use compression fittings on the pipes, or in my case i have aluminum fittings tig welded on, since my system is all AN.
