Page 2 of 12 FirstFirst 123456 ... LastLast
Results 26 to 50 of 296
Thread: AccordB20A's EG Civic Build
    Re: I has a civic - update thread
    Ok theres is something seriously fucked in this coupe i have no idea what it is
    - Changed main relay, battery, fusebox, same problem
    - changed engine, same problem
    - changed ecu, same problem.
    - changed fuel filter, same problem
    - continuity tested every wire that goes to a sensor in the engine bay (checked out fine) and still had the same problem
    - changed car wiring loom, same problem
    - Changed Fuel Pump, same problem
    - Changed fuel lines, same problem
    its like this car has a curse on it, its had three motors now all three do the same thing, im stuck and i have to give up, theres really NOTHING more i can do
    News with the civic, it now has no wiring loom as i took it to use in the coupe, but that failed so i guess ill be taking that loom back. its pretty stripped now, no dash etc etc
    2.0Si User cubert's Avatar
    Feb 2003
    2012 Civic si, old bikes.
    NH
    hows the spark? Probably a long shot..but hey..who knows
    tps?
    sparks fine fuels fine tps is fine ive tried three different engines lol
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    duz sound like an ignition break down to me.
    like its running on 3 when you give it some throttle.
    have you tried a diff distributor and leads?
    Umm..sounds like its choking. something with the dizzy..i couldnt find out for you bro. my buddy had no clue also
    Yeah theres no such code as 11
    why would three different engines on 3 different dizzys and 2 sets of leads do the same thing??
  9. #34
    Sep 2007
    new zealand
    possibly a clogged fuel filter not allowing enuf fuel thru, that can sound similar to ign break down.
  10. #35
    LX User 3rd Party's Avatar
    Jan 2009
    1987 Honda Accord LX-i (4dr)
    Boise, ID
    MAP sensor maybe? i know when the MAP sensor's not hooked up it sounds like dick under load, and when revved. especially with MAF sensors too...but i may have over looked this replacement...so void this post if so.
    1987 Honda Accord LX-i (A20A3) (179k)
    79-whp, 103-wtq (Performance Solutions)
    "...if you type, 'Google' into Google you'll break the internet..."
  11. #36
    fuel filters mint theres heaps of fuel pressure etc and flow getting to the fuel rail, return line works good, I think im going to put the coupes engine into the hatch and hook it up and see what happens lol
  12. #37
    Jan 2009
    Boise, ID
    i suppose the MAP sensor checked out then?
  13. #38
    me thinks the coupe is cursed
    edit:
    hows the grounds? my accord ran simular to that when its grounds were fried . check all of them maybe one going to the ecu is cacked or something
  14. #39
    yes its not throwing map codes i think the grounds r all mint
  15. #40
    hmm weird. if all else fails i reckon u could kill it with fire!!
  16. #41
    yeah thats what i said i would like to burn it, but ill have a play with it tomorrow and see what i can make it do.
  17. #42
    Jan 2009
    Boise, ID
    now's a good time to get that wanted expierence in with napalm...HAHA
  18. #43
    riiiiiiiiiiiiiiiiiiiiigggggggggggggggggggggggggggg ggggggggggghhhhhhhhhhhhhhhhhhhhhhhtttttttttttttttt ttttttttttttttttttt
  19. #44
    o2 on the exhaust is same one too?
    coolant in the system the same?
    same battery? alternator? what is the charging voltage anyway?
    over 16vdc?
    giood luck
  20. #45
    tried unplugging the alternator etc nothing happened same with the speed sensor
    put the loom back in the hatch with the coupes old motor and it fired up perfectly
    my what the fuck face is on
  21. #46
    thats wierd bro
    Im going to have to let my mate sort this out im stumpted, swapped everything i can
  23. #48
    Okay heres an update on the civic, went and robbed a car for its manual parts yesterday including a 5 speed B series gearbox:
    b series swap on
  24. #49
    LXi User diegoaccord's Avatar
    Jun 2001
    BB6 Lude, EG Hatch.
    It sucks.
    Doesnt look worth the trouble. that shit is BEAT. Im sure there HAS to be some EG hatch for cheap better shape than that. You didnt scam him, he scammed YOU.
    All the coupes are built in US. Even JDM coupes. All vins begins with 1HGEJ1(EX) or EJ2(DX) same with EK coupes. And also unmentioned are EJ7, which are HX's. All JDM 96-00 coupes were EJ7's also.
  25. #50
    Fixed the coupe today, the problem was the catalic converter was like 99% blocked, no wonder it wouldnt rev!! so thats all going fine
    The civic isnt too bad only looks it in the pics, 2 nre lights 2 guards a right front door and it will be minter
    eg civic over here are worth heaps still even if they are de registered and crashed so im not going to get a better deal than this one
  1. AccordB20A's 2.0Si F1 Edition Build
    By AccordB20A in forum Project Central
    Last Post: 10-12-2014, 02:38 AM
  2. AccordB20A's 1g CRX thread
    Last Post: 08-10-2012, 10:13 PM
  3. EK Build Up and Engine Swap - '78 Civic
    By redr2 in forum 1geez Tech & Performance
    Last Post: 08-26-2010, 08:06 PM
  4. My winter beater stereo build: '93 Civic EX sedan
    By Hash_man_Se_i in forum Interior & Exterior Care
    Last Post: 12-25-2009, 02:45 PM
  5. AccordB20A's 2.0Si F1 Edition Build
    Last Post: 10-14-2009, 11:49 PM
