Results 1 to 8 of 8
Thread: strange idle
    87 accord lxi
    kansas
    Question strange idle
    while my car is idling (like at a stop light or something) i can feel little like "hiccups." with every "hiccup" my lights dim. i have a new battery(3-4 months, it's an everstart), and i'm going to replace my plugs tommorow. any ideas?
    10/Honda/Ridgeline
    NJ
    check ur vacuum lines.
    10/Honda/Ridgeline
    NJ
    also, see if ur ecu is throwing codes.
    Oct 2001
    87 Accord EX , 5spd , Manual
    you mean your idle is going high and low ?
    MIKE
    87 accord lxi
    kansas
    no, there are just little jerks almost like a misfire only much less noticeable
    the "hiccups" are probably just causing your alternator to spin slower and therefore causing them to reduce output at every hiccup and this makes your lights dim
    Eric
    89 Accord LXI FI Auto
    Charleston, WV
    Is your cooling fan working? I might be trying to come on and failing.If it does work check your spark plug wires, cap and rotor.
    Oct 2001
    measure your battery voltage while car is running should be STEADY 14.5 volt ! and about 15 V at 3000 rpm !
    MIKE
  1. A few strange idle-ish problems...
    By Feuerstoss in forum 3geez Accords
    Last Post: 11-21-2005, 03:07 AM
  2. strange intermittent high idle
    By Strugglebucket in forum Carburetor Tech
    Last Post: 08-13-2005, 12:41 PM
  3. Strange idle, 1000rpm to 800 up and down
    By FyreDaug in forum 3geez Accords
    Last Post: 03-12-2005, 03:52 PM
  4. Strange
    By A20A1 in forum 3geez News & Site Feedback
    Last Post: 09-23-2004, 06:10 PM
  5. Help- my brakes did something strange
    By crwa in forum Performance
    Last Post: 05-04-2003, 07:46 PM
