Page 1 of 4 1234 LastLast
Results 1 to 25 of 82
Thread: getting a new water pump
    LX User slacker's Avatar
    Jul 2007
    88 LX Sedan, 87 DX Hatch, 94 EX Sedan, 97 Firebird, 00 Firebird
    Maple Shade, NJ
    Question getting a new water pump
    Hi all,
    The water pump on my 88 LX has recently started making weird noises so I will be getting it replaced soon. I bought the new part and it's ready to be installed.
    The car has approximately 174,000 miles on it and I do not know if anything has ever been replaced other than the radiator and spark plug wires as I've just recently purchased it.
    I was wondering if it would be a good idea to get the timing belt, tensioner, and accessory belts replaced, too, while I'm at it so I don't have to deal with it later.
    Also, should I get it done myself or get someone to do it for $150? I've never done this before and I have no experience so I'm not sure how hard it is.
    Any advice would be appreciated. Thanks all!
    Re: getting a new water pump
    yeah i would recommend doing everything at once so you don't have to worry about it anymore.
    and i think it would be a good learning experience for you to do it your self. but i would recommend downloading the manual and reading the process of doing it and then if u feel u cant do it then pay to have it done.
    also when doing the timing belt it is about the same time u should adjust valves. this is very easy and you should be able to do it your self
    heres a how to on that
    https://www.3geez.com/forum/showthread.php?t=39319
    if you dont have a feeler gauge you can pick one up from vatozone for around $6
    the water pump can be replaced without taking off the timing belt if needed. it's external not internal.
    Idaho
    Yep, it's not very difficult at all if you like working in confined areas.
    Jul 2007
    Maple Shade, NJ
    Thanks CAH! Really.. There goes my weekend.. Lol. OK that's a 150 bucks I will save and spend on my new stereo
    2.0Si User cubert's Avatar
    Feb 2003
    2012 Civic si, old bikes.
    NH
    Yes..you should definitely do it all at once.
    If you feel confident in giving it a shot, then do like CAH said and download the shop manual, and take your time.
    Jul 2007
    Maple Shade, NJ
    should i leave the timing belt as it is then since it still has good tread on it and it doesn't look so worn out? that way i wouldn't have to deal with the tensioner, either
    thanks for the quick responses, guys
    Quote Originally Posted by slacker View Post
    if you are going to replace it get a kit with a tensioner and belt, it's not that bad to do,there are a lot of good write ups on here and we will help you through it.
    Jul 2007
    Maple Shade, NJ
    yup.. already ordered a water pump, a timing belt, a tensioner, and an alternator belt. i should be getting them all by monday, the latest thanks for the support!
    i would replace it just to be on safe side. its not very much and will save you a big headache later on if it decides it wants to snap one day in the middle of no where (and thats were they always decide to break )
    so yeah since your going to be working in that area it would be an excellent idea just to do it all at once
    thumbup:
    Idaho
    It's a beautiful thing to see that you have grown up from a child to a man...brings a tear to my eye.
    Feb 2003
    NH
    Idaho
    But quit using spray paint like a damn monkey on acid! Ok, enough with the post whoring.
    It's not too bad to change a water pump, timing belt etc. Just don't drop the woodruf key or lose it.
    Jul 2007
    Maple Shade, NJ
    Where do i find the woodruff key, on the camshaft pulley?
    I hate to be the wet blanket here, but the timing belt is NOT the place to begin your mechanical pursuits. It is a half day job at least, and that's if everything goes well. If you "have no experience," it's not going to go well. You probably don't even have the tools you need. You're going to get to the crank bolt and you'll never get it off. If you get past that, you're not going to be able to get the new belt on. Monday morning will come and your car will still be torn down and you'll be bumming rides to work. You'll break stuff and hurt yourself, sell the car and swear never to try working on your car again. If you want to start wrenching, start with oil changes and spark plug replacement. Work your way up to a timing belt replacement.
    Sorry to be a contrarian.
    Jul 2007
    Maple Shade, NJ
    I think I explained myself wrong. I meant that I have no experience with timing belt or water pump replacement. I've changed my oil many times before and I have also done spark plug replacements, although I've only done it once or twice I got as far as changing my radiator a couple weeks ago but I've never actually done anything with the timing belt or anything around it. Matter of fact, I'm still trying to figure out where the stupid transmission dipstick is so I can check the fluid. But I'm willing to learn as this is not going to be the last time I work on a timing belt or a water pump if I do it once. I am not quite sure if I have the proper tools, though, so thank you for pointing it out. What do I exactly need other than my socket wrench set?
    Thanks!
    LX User mephi's Avatar
    Apr 2004
    1987 Accord DX 4 door
    Port Orchard, WA
    If your car is a manual, there is no dipstick on the trans. If it is an auto, there will be a short aluminum top dipstick screwed into the top.
    I was about where you were when I changed my first 3gee timing belt. It took me about a week to completely finish the thing. Getting that crank bolt off without an impact wrench is a bitch. It can be done, but you may want to get a few more tools. I can do them in a few hours now.
    This is a great car to learn on though. It was what really made me decide to get into automotive repair. That and my Jeep. I went from changing timing belts to clutches to pulling engines and lifting trucks.
    replace everything while in there...also dont forget to get OEM honda parts...they tend to last longer
    Jul 2007
    Maple Shade, NJ
    Quote Originally Posted by mephi View Post
    It's an automatic. I'll go out in a little while and try to locate it in daylight once again. I think this car is a good start, too, as it seems like it has a simpler engine than any other car I own. Thanks for the support.
    Uhm.. I think I got all aftermarket already.
    Here's what I got so far:
    NSK Timing Belt Tensioner
    ITM Water Pump
    Cloyes Timing Belt
    Bando Alternator Drive Belt
    Are these too bad?
    ITM Water Pump
    Cloyes Timing Belt
    Are these too bad?
    well dont worry about it...at least you are changing them...
    the parts should be just fine
    alot better then the 20 year old ones in there
    Jul 2007
    Maple Shade, NJ
    uhmm.. 21 years. let's get it straight.
    hopefully i will be able to work on it this weekend. i already received the timing belt and the alternator belt in mail.
    nsk is good, they make the best wheel bearings for this car, I think oem too, cloyes is also good
  1. Timing Belt, Water pump, Oil Pump Questions....
    By fuzzy audio in forum 3geez Accords
    Last Post: 11-07-2014, 08:15 AM
  2. Leaking oil pump / timing-water pump RnR
    By mward in forum 3geez Accords
    Last Post: 10-19-2010, 03:29 PM
  3. Replies: 16
    Last Post: 11-05-2004, 09:21 AM
  4. FS: A20 Water Pump
    By BootMachine in forum Trading Post
    Last Post: 04-08-2004, 10:31 AM
