is it possible to install a turbo on my car that came from a junkyard car? like an eclipse or a talon, or a volvo or saab? maybe even a christler? like make my car turbocharged out of junk yard parts?
lol...i got a dsm turbo...but no walk in the park...total kit 1,500
absolutley yes, as long as the said turbo is in usable condition
you will want to research the models used in which oem apps so you know the specs
Also Study it...dont just think oh im putting a turbo on LOL no no no my friend...you need a way to supply fuel and control em...so a safc and btm and 450cc blue tops if you what or a lower 340cc.. you need to make your own manifold an charge pipes. if need a half size radiator. theres no way your gonna get a t3 in ther unless you do a side mount. Anywho. learn how the redo your pcv system under boost. need to get a base start on safc and timming. and need to figured how to make a down pipe which a ass face to do Need to have money lol...something i didn have for awhile...alot of things to consider...Do a comp test and make sure your block can take it...if one of them is lower i wouldnt do it...SO man do your research...I can tell you i learned most of turbo basics on homemadeturbo.com...hoped i help
Rendon
sorry rendon but i only understood about half of what you said.
for example:
"and need to figured how to make a down pipe which a ass face to do Need to have money lol"
WTF?
grammar fail lol.
honduh
A... I dont care if i write fucked up....point is bro...you need alot of shit
manifold
injectors
obd1 or safc
btm
downpipe
turbo...w/e
half size radiator
tuning
what im saying its not a walk in the park...you got half the shit i told you so dont give me that crap lol...i was buzzing at the time. RESEARCH thats all im going to say...asking alot of questions not going to help but piss half of us off when you can use the search button COOL? k
I figured well i got a turbo should be easy NOT...if you have a buddy that welds for free there you go. Im just saying once again research dont ask....been plenty of questions on this topic on this ,theres is a STICKY for a fact on this forum....try that...tells you everything
yeah yeah what he had said, I thought OP meant just the turbine. But yes, the turbine is only part of it, you still need the plumbing and an engine management system or modification that can be interfaced to adjust the injector function and timing curves.
You can rig up a rough boosted set up with bare bones parts but it will not last very long. The whole idea with a turbo set up is durabiltiy, reliabilty, streetability.
so what can you do to our cars that will add 30 hp without 1500 dollars?
intake.header,exhuast done from header, cam. b16 intake manifold. shit like that well get you about 20 hp gain but to gain high numbers you need forced induction.
yeah turbo can get costly....you also got to remember to get a good clutch....hardest part is to get a manifold and tune it
yup....thats why im going obd1....MESSY HINT HINT LOL....
um header is a bit steep....bout 200, cam is 120 from delta. b16 mani is 25-30 bucks. exhuast it verys depending where you live..i get hook ups lol but
lol....just cause its a lxi bro doesnt mean its 130...lol...carb 98 and lxi 110
Yea, or get a A20a4 dizzy and ECU, that way no EGR, than it makes 122hp. plus every thing Randon, Roodoo and Messy mantioned, you'll have 145hp tops, minus 25% on friction so by that you'll only have around 105-106Hp@wheels
My Build Thread
what if you get a a20a4 and a ecu.....and no CEL for egr? im used to it anyways
i've been running no EGR for over year and dont throw a code unless i unplug the sensor wire for it. i just made an aluminum block-off plate for the pipe to manifold connection. blocked off the exhaust port. used some Permatex black on the intake manifold, all is well.
-Harvey
you have a 88/89 thats the reason. But i wont have that after obd1 swap
