Results 1 to 11 of 11
Thread: Fouled Plugs
    bridgewater.NS Canada
    Exclamation Fouled Plugs
    Hey guys my plugs have been fouling up lately and it's been running crappy.A mechanic i know said it was most likely my valve seals.I know my valve seals are bad but would this be causing my plugs to foul up.Is there anything i can add to the motor to help this,i can't afford to do the valve saeals right now.
    Re: Fouled Plugs
    Nobody ?
    itzdave's Avatar
    Jul 2006
    1990 Mazda Miata
    Missoula, Montana
    Re: Fouled Plugs
    yes, dependeing on how bad the seals are, it will make the plugs foul...
    Apr 2008
    1983 Accord DX Hondamatic Sedan
    Lancaster, Great Britain
    Re: Fouled Plugs
    As a temporary fix do you have 'valve stem seal additive' in the States, Made over here by a company called Millers Oils. My son stuck some in his oil on a smokey old Ford CVH engine and it cured it, I don't know how long for because 2k later he totalled the transmission, so we scrapped the car....
    Cost about £5 and cheaper than a rebuild.
    Re: Fouled Plugs
    if your stem seals are bad, oil will seep down into the cylinders and foul the plugs, it also will smoke when you first start it up. I know when i replaced mine, the exaust ones had deteriorated to nothing.
    Re: Fouled Plugs
    Do you have a carb, that could be the problem also
    Re: Fouled Plugs
    Yes I'm carbed but when i start it up in the morning it runs fine til I get to town,then it starts tolose power and bucks.I changed the rotor button,checked the timing took off fuel line to see if it was getting enough gas and it was fine,even put in supreme gas to see if that will help.I also wired the choke open and ditched the air filter cause it was dirty,will see in morning how it runs.
    Apr 2008
    Re: Fouled Plugs
    You never mentioned the dirty air filter, petrol engines, like humans, need air to function. 3 rules of petrol engines, fuel/air/spark. If one is missing, no go. But too much air will lean the engine out and can burn out your valves. Depending on how clogged your air filter was, you could be suffering from nothing more serious than plug sooting, like when you forget to push the choke back in.
    Re: Fouled Plugs
    Well the car still doesn't run right in traffic going slow it sputters but when i get out of town and can rev it ,it runs better.I'm getting another carb and swapping it this weekend,also gonna seafoam it.
    Ichiban's Avatar
    North of You.
    Re: Fouled Plugs
    Try pulling the air filter lid off while the engine is hot, and see if the choke is fully opened. Try that before swapping carbs.
    ICHIBAN!
    "Now, even more better!"
    Re: Fouled Plugs
    The choke was open when i checked it,but i wired it open .car seemed to work better today,i think there might have been some crap in carb that worked it's way through.still gonna seafoam it on the weeken.
  1. Spark Plugs
    By FORFREE in forum 3geez Accords
    Last Post: 04-03-2006, 11:14 AM
  2. Oil leaking through plugs?
    By pisnapalm in forum 3geez Accords
    Last Post: 11-19-2004, 10:12 AM
  3. NGK Iridium Plugs
    By JusDreamin' in forum Performance
    Last Post: 11-09-2004, 09:16 PM
  4. fackin plugs!
    By dXsquared in forum 3geez Accords
    Last Post: 05-26-2004, 04:02 PM
  5. Egr Plugs.
    By Bronx89lx in forum Carburetor Tech
    Last Post: 02-04-2004, 09:59 PM
