Page 1 of 3 123 LastLast
Results 1 to 25 of 64
Thread: Wanna go with bigger wheels? Better get aftermarket studs!
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Anyone else had this happen? Lost 3 out of 4 studs!
    Re: Wanna go with bigger wheels? Better get aftermarket studs!
    your b20 is just a beast....haha...time to upgrade to ARP studs
    Reason you lost them is because they're stock 21 year old studs. I have brand new studs up front and the rear(except one side).
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    I've never had a problem...
    Judging by the center of that hub, it's newer chinese garbage.
    CARDONE SUCKS.
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    i've only ever seen wheel studs break coz of over tightening.
    diff offset wheel can stuff wheel bearings a bit quicker but never seen studs break like that before
    extended studs FTW!!! problem is stock is too short for the fatter base of aftermarket rims so the lugs dont get enough threads.
    indeed overtightening but never snapped by themselves
    ya but that would only possibly cause them to strip off not snap
    89T's Avatar
    Apr 2004
    all 3 broke off at the same time? It looks like the top left stud has been broke for awhile. Maybe it's a shadow.
    Anyway judging the ring left on the caliper from the wheel it seems that the hub diameter on the wheel is too big.
    The wheel should fit tight to the hub. If the wheel doesn't fit tight to the hub then all of the weight of the car sits solely on the studs.
    I have seen this happen twice, one guy hit a big pot hole and snapped them off. The other snapped them on a hard launch with drag radials.
    un-motivated!
    3GR
    Seems like there where loose and not tq. so they busted up...that an big wheels just a no no bro alot of stress...thats why i have 15..if you went that route and lower it man that would be sexy
    they fatique from being old, the ARP studs are cheap, get them, and the weight of the car is supposed to be on the studs, thats why it's so important to use the correct lug nuts for your wheels, if you use the wrong ones there is movement between the wheel and the stud and this same thing can happen. the lug nuts have to fit in the correct taper, this centers the wheel on the stud, and is what actually carries the load.
    could look in to something like this
    http://passwordjdm.com/Blox-Racing-E...ds-P599C0.aspx
    snoopyloopy's Avatar
    Killa Cali
    no, never happened to me.
    to think we rely on 16 of those little tiny pieces of metal to not fail at high speed :O
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Got these on order
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    And open end lug nuts are the only ones that will work for these studs
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    I think it was the stress of having the bigger 17 inch rims. The shorter lugs are only made to suppoprt a factory 14 or 15 inch rim which is why they gave out. The extra weight from the bigger rims caused too much stress on the lugs I guess. Im still impressed that they lasted 2 years on my car before they broke.
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Quote Originally Posted by 89turbo'ed View Post
    Yes the first one was broke for a while apparently.....And I thought the noise i heard was coming from the intermediate shaft lol. Would have never thought it would be the lugs
    thats why when i did my suspension work i used all arp studs. the end of them is also made in such a way that it's harder to cross thread them,makes it eaisier to start the lug nut
    Quote Originally Posted by bullard123 View Post
    the open end is fine,i was talking about the taper between the rim and the lug nut sides. there is really no difference between open end and closed end lugs,other then appearance. the part that contacts the rim is whats important.
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    ok yes that is cool...I think the only difference is that the closed lug nuts wont tighten all the way. And the open end ones will tighten down all the way
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    You need to buy some hub-centric rings by the looks of it, otherwise the same thing is bound to happen sometime down the road. Having all of the weight and stress of the wheel transfer to the studs will cause that to happen, whether they are ARP or Stock.
    the weight is supposed to be on the studs, no one understands this, thats why the lug nuts have a taper that matches a taper on the hub, they fit like a key in a lock. the pressure from tightning the lug nut on the stud forces that taper into the taper on the hub. thats what holds your wheel on. the only time the center of the hub holds it is if you had something like halibrand knockoff centers or something else without lug nuts. the lug nuts and lug studs hold the wheel on the car. I see people all the time with the wrong type of lug nut on their wheels and wonder how long till they bust off the studs.
    here's a good picture from tire rack, the tapered area is where all the force from tightning the lugs is at, this is what actually holds the wheel to the car, this is also why it's so important to torque your lug nuts correctly.
    bullard123's Avatar
    Nov 2003
    1988 Hatch LXI
    COLORADO SPRINGS
    Good info Lost
  1. stripped studs
    By coope in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-29-2007, 02:34 PM
  2. Aftermarket Steering Wheels & Cruise Control Relocation
    By 88accordSF in forum 3geez Accords
    Last Post: 04-21-2007, 08:22 PM
  3. Can you drill bolt holes bigger without F-ing up the wheels?
    By Mike's89AccordLX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-12-2004, 01:49 PM
  4. Replacing wheels studs?
    By deevergote in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-28-2004, 08:45 AM
  5. Re-calibration of Speedometer for Aftermarket Wheels
    By MIK3 in forum Classic Honda Community Chat
    Last Post: 04-25-2004, 04:44 PM
