Results 1 to 24 of 24
Thread: Amp Help
    SEi User 86ccord's Avatar
    Middle Georgia USA
    Amp Help
    alright i came across a kenwood amp its a 1000 watt amp and it puts out wayy more than 1000, anyways it blows the amp fuse every so often and i was wondering how i could fix it..
    one day I'll return.
    Joay's Avatar
    Sep 2008
    Misty Beige 1988 LXi Coupe
    Re: Amp Help
    Turn down the gain, maybe?
    Is it 1000w RMS or peak? If it's rated for 1000, it should be peaking at no more than 1000.
    Re: Amp Help
    lol an amp that actually put out more then 1000watts rms would be quit expensive
    are you talking the inline fuse on the power wire or the one on the amp its self
    also a fuse size and amp model number would be sweet info to have
    Re: Amp Help
    are your subs wired correctly. Make sure they have an Ohm level the amp can support. This would cause you to blow fuses.
    Re: Amp Help
    it has to be 1000w max amplifier as a 1000w rms amp would have some meaty fuses, mine has a couple of fuses (80 amps) and its factory rated around 1000w rms into 4 ohm
    Joay's Avatar
    Sep 2008
    Re: Amp Help
    Well yeah a 1000-watt RMS amp would be a real motherfucker, but it seems weird to put out far more than its rated peak as op describes.
    Middle Georgia USA
    Re: Amp Help
    hmm.. this amp only requires 40watt fuse.. and its the fuse thats on the outside of the amp.. like you plug into the side of the amp..
    Middle Georgia USA
    Re: Amp Help
    lol yes my sub is wired correctly..
    Re: Amp Help
    Ok so the amplifer works right? like it makes sound until you crank it up too loud then fails? Does it blow the fuses under extreme load, also does the amp get quite hot from doing no work?
    Re: Amp Help
    what kind of sub and how is it wired is it a dual voice coil
    is it bridged on the amp
    more info
    plox
    Middle Georgia USA
    Re: Amp Help
    yeah, when i crank it up the fuse blows..
    more info
    plox
    its a audiobahn 12 dont know the model, and its just hooked to the negitive and positive on the amp, and just ran striaght to the negitive and positive on the sub
    Re: Amp Help
    Maybe it wants a bigger fuse, how loud can it go before it blows? loud enough to hurt your ears?
    Also can you possibly supply me with the model of the amplifier
    Re: Amp Help
    40A fuse you mean? Is that stock size? Sounds awfully small to me.
    Model of the amplifier would help here.
    Middle Georgia USA
    Re: Amp Help
    yeah 40a.. but the model is kenwood kac 7252
    Re: Amp Help
    40a sounds stock, its not that powerful of an amp but it is 2 ohm stable.
    - 1,000 Watts max power
    - 170 Watts x 2 (4 ohms) RMS
    - 250 Watts x 2 (2 ohms) RMS
    - 40A Fuse
    it says its biridgeable but it doesnt say what its bridged power output is on the page i looked at, Maybe around 250w rms bridged, but that should by no means blow a 40A fuse
    Middle Georgia USA
    Re: Amp Help
    - 40A Fuse
    yeah..there is like a shortage maybe? idk.. i went through a box of fuses in two days..
    Feb 2004
    89 accord lxi
    down by the bay
    Re: Amp Help
    Make sure your amp's ground is good.
    If you're bridging the amp your sub needs to be no less than 4ohms.
    Re: Amp Help
    try another sub, if you dont know the model it may be a 2 ohm sub and in bridge mode that will cut out at higher volume, and maybe blow your fuse, try another known 4 ohm or even 8 ohm sub. If you can get another sub try it on one chanel
    Middle Georgia USA
    Re: Amp Help
    Quote Originally Posted by Strugglebucket View Post
    ground is good.. and i belive the sub i have in it now is 4ohms, cause when my brother bought the amp, he had it set up for the sub im running now.. ( which is his old system..)
    and ive had 4 diff subs.. i think i will just stop being cheap and buy a new amp.. and call it a day..lol
    89T's Avatar
    Apr 2004
    Re: Amp Help
    when your amp blows the fuse is the heat sink hot?
    what size power wire are you running?
    un-motivated!
    3GR
    Middle Georgia USA
    Re: Amp Help
    Quote Originally Posted by 89turbo'ed View Post
    the amp is warm, but nothing other than normal running temp.
    uhh not sure the size, but its a fat one from the battery to the amp, it came in my kenwood 1000w wire kit..
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    Re: Amp Help
    I;d say your amp is either screwed or possibly not being bridged properly, or it just doesnt like being bridged.
    Re: Amp Help
    ya try taking the bridge off and just running it on a single channel
    Middle Georgia USA
    Re: Amp Help
    ya, my uncle he deals with stuff liek that and i sent him the amp, and he said it was toast.. but idk..
    ok ill try that and see what happens.. thanks.
