I've been trying to chase down this pop sound I get when I roll backwards and apply the brakes. First thing that came to mind were ball joints. So I checked over all of them with a crow bar and none of the budged. I put enough force to bend the crow bar, and non of them budged at all. Car tracks straight, no vibrations, no popping or creaking under any circumstances. This only happens every so often when rolling backwards. Any ideas?
Heres whats done to the front end.
-Upper control arms with new bushings
-Tie rod ends and reman rack and pinion
-Moog lower control arm bushings
-Wheel bearings inspected when studs were replaced. They spin smoothly and no play.
-Axles have 30k or so on them.
I thought that it could be my brake pads shifting as after I mess with the brakes the noise disappears for some time. I've lubricated the caliper guides before and the noise went away from a few weeks but then came back again. Any ideas?
