Results 1 to 4 of 4
Thread: Cam wear
    LX User mephi's Avatar
    Apr 2004
    1987 Accord DX 4 door
    Port Orchard, WA
    Cam wear
    How much do you need to worry about small scratches or grooves on the cam bearing surfaces?
    And you will know me by the cloud of smoke.
    Re: Cam wear
    not good, could cause low oil pressure, broke cam, oil consumption. depends on how bad it is grooved. You can try using it but keep an eye on it for a while to see potential issues. There was someone here that knew a place that would machine them down to use actual bearings.
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Re: Cam wear
    I wouldn't worry so much about the oil pressure as it's metered by the "oil whistle" in the block. The oil supply to the head components is actually gravity fed, with the excess exiting through notches in the top of the cam/rocker caps 2 and 4.
    CARDONE SUCKS.
    Re: Cam wear
    ahh ye ole oil whistle.. lol remembering my thread from way back
    good point, the f22 is bad about that though from my understanding
  1. wear your respirator
    By lostforawhile in forum Classic Honda Community Chat
    Last Post: 12-03-2009, 08:26 PM
  2. checking b20a flywheel for wear?
    By mykwikcoupe in forum JDM B18A / B20A Swap Tech
    Last Post: 03-16-2008, 12:33 PM
  3. very wierd tire wear? :(
    By johnwc723 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-20-2004, 08:46 AM
  4. why do my tires wear unevenly?
    By jay in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-28-2002, 12:14 PM
  5. Front tires wear out unevenly
    By Longevity in forum 3geez Accords
    Last Post: 05-30-2002, 10:22 AM
