Results 1 to 6 of 6
Thread: New here. How does the rear door quarter glass come out on 88 accord sedan
    LX User Bluntman's Avatar
    Apr 2009
    1988 Honda Accord LXI
    Orange County Cal.
    Have to replace the chrome molding on the outside of the door, but it looks like if I pop the quarter glass out it would clear the lower rubber seal of the glass easier. Looks like the glass will just push out then put back in with string. Thought I would make sure first.
    Pulled the molding at pick you part cost $4. Thanks guys.
    Joay's Avatar
    Sep 2008
    Misty Beige 1988 LXi Coupe
    Re: New here. How does the rear door quarter glass come out on 88 accord sedan
    I think stationary auto windows are sealed with a kind of caulk substance. You can take it out, obviously, but I doubt it will pop out and right back in without breaking a 21-year-old seal and leaking. You can buy stuff to re-seal it though.
    i know a couple of the members know how to remove them messy and pico wait for one of there responses before going and buying stuff
    Apr 2009
    Orange County Cal.
    Thanks for the info so far. I started to do one at the junkyard to practice and it didn't seem to be sealed with any adhesive, but was in a hurry to pull parts that I wanted. I was pushing it inwards, but I am wondering if I push outwards or have to pull the door panel and remove the the rear window guide between the rear door window and the quarter window. You guys are OK in my book.
    You have to remove the larger window, then the channel. There are two screws under the weatherstrip at the top of the channel and two more down in the door. It should come out easy when you remove the channel. This is all in the shop manual, available here:
    http://honda.roadpwnage.com/manuals/...-1989-full.php
    Apr 2009
    Orange County Cal.
    Thanks alot. That is what I was kind of figuring, but was not sure. I may try to put the molding on without removing the glass. I may be able to get the clips and molding to go down and then just bring the small lip of quarter window rubber at the bottom back over it with a trim tool. I pulled the molding without removing the window. But putting it back in may be a bit different.
    I also fixed my pop up headlights that always stayed up. Traced it to the switch in the dash. Pulled the block fo 3 switches (headlight retract,dimmer,rear defrost) and paid $8 for the whole block. I like pick your part by my house, I have found many 86-88 accords there. It's a candy store.
  1. Rear Quarter Panel Help
    By azazel_18_2 in forum 3geez Accords
    Last Post: 06-13-2007, 07:12 PM
  2. Rear Quarter Window...
    By 88LXi68 in forum Interior & Exterior Care
    Last Post: 04-26-2006, 01:20 PM
  3. Flush rear quarter windows?
    By Forgar_88 in forum Interior & Exterior Care
    Last Post: 06-25-2004, 04:41 PM
  4. FS...89 Accord Rear Window Glass
    By BootMachine in forum Trading Post
    Last Post: 01-14-2004, 11:10 AM
  5. WTB Passenger side door and rear quarter trim.
    By Poodlehead in forum Trading Post
    Last Post: 09-15-2003, 04:06 PM
