Page 1 of 3 123 LastLast
Results 1 to 25 of 65
Thread: Complete OBD 1 Conversion Harnesses
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Finally, a complete obd1 wiring solution for our accords! Thanks to the persistence of several of the members on here, some really neat stuff is becoming available. What better to top it off with?
    All connections are crimped, soldered and sealed at the connector for ultimate reliability. New automotive wire is used in all runs, beautifully loomed and taped. Designed to be fully plug and play and easily removable.
    You will also need a obd1 ECU, distributor and adaptor plate.
    86-89 Accord obd0 - obd1 ECU jumper $100
    Includes connector for extension harness. With vtec connector add $7.
    ECU extension harness $70
    Connects to ecu jumper to run extra wires to the engine bay. Includes vtec.
    A20A3 obd1 add on engine harness $120
    Plugs into ecu extension harness. Connects to additional sensors, obd0 distributor plug, and stock coil to allow you to run obd1. Includes ELD and mounting bracket. O2 front placement.
    86-89 Accord obd0 - obd1 distributor wiring adaptor $65
    Perfect for those inclined to run all the extra wiring themselves. Includes weatherproof crimps and wiring to the stock coil.
    I will also entertain the idea of modifying your stock engine harness to your specs for obd1 and/or B series motors. ECU jumper and extension harness will remain the same as the A20 for these. PM me with details for a price.
    This thread was started here and not in the for sale section to answer any questions and to allow for input. Actual transactions will be handled with private messages.
    CARDONE SUCKS.
    Re: Complete OBD 1 Conversion Harnesses
    did you use shielded wire?
    Sep 2006
    Tucson, AZ
    Yes, shielded wire was used for the o2 and crank position sensor wires.
    CARDONE SUCKS.
    AZ
    i see how it is
    good job on the collage that's pretty much what i was thinking...
    and as for the quality of this product it is A+ top notch... all new wires on the sub harnesses with perfect seals on every plug. definitely the easiest solution to the wiring problem!
    dead white and blue
    man thats tits to bad i traded back my mounts to tommy so he would have to spend the extra cash on me lol
    so if i just wanted to go obd1 with the a20, all i would need for the ecu is this "86-89 Accord obd0 - obd1 ECU jumper $100" and none of the other stuff? or would i still need to run wires for the o2 sensor?
    Im going to have to get a couple things
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    Awesome work!!
    ^^you would need all those parts unless you want to make some of the wires yourself. You usually wont need every single wire unless you swap in a vtec engine with stock ecu.
    Link to my 3geez garage
    AZ
    you would need all of the pieces here for the closest plug-n-play application you're going to get... otherwise you need to do a lot more than just an o2 sensor...
    couple this with the plate and you have a full setup and it's as simple as bolting and plugging.
    dead white and blue
    AZ
    sorry tdurr you would need the jumper and this:
    dead white and blue
    i was just talking about the stuff in this thread. I know about the dizzy and all that jazz.
    but it looks like anyone who wanted a simple plug and play would just need to get the two things rendon has qouted.
    Sep 2006
    Tucson, AZ
    For plug and play you will need the ecu jumper, extension harness, and engine harness.
    The distributor adaptor and ecu jumper can be purchased separately, if you want to run your own wires.
    I will stand behind all my work 100%.
    CARDONE SUCKS.
    Feb 2004
    89 accord lxi
    down by the bay
    Pretty slick.
    So the engine harness your'e making is sort of supplementing the existing harness, rather than replacing it?
    AZ
    Quote Originally Posted by Strugglebucket View Post
    Pretty slick.
    this is correct.
    dead white and blue
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    Hmm this is fantastic! I don't recall you saying it was going to be this expensive though. Well as soon as I get enough money for this I will PM you.
    Andrew.
    ^^ the labor involved in doing wiring is very time consuming. i kno. price isnt too bad. how long does it take to make each one?
    Sep 2006
    Tucson, AZ
    4-5 hrs for the engine harness, 3-4 hrs for the ECU jumper, and another 2-3 for the extension harness. Then there's the gathering, depining and cleaning of the stock connectors... I have $60-$70 in wire alone for each complete setup, about 3 rolls of $3.80 Super33 tape, loom, heat shrinks, and solder... I've said $290 for the complete setup from the very beginning, I can't justify doing it for less.
    CARDONE SUCKS.
    so whats the extension do... i really need is to run dizzy correct? well either way ill have to get those. I see that the extension is for vtak..but im not or ever going to have Vtak lol
    Sep 2006
    Tucson, AZ
    Runs the extra wires from under the seat to the strut tower. The add on engine harness connects to the extension harness there, like the stock engine harness connectors.
    I can combine the engine and extension into one continuous run, and knock off like $10-$15, but it'll be a week or so for me to build it.
    No, you will get a CEL for the O2 without the extra 3 wires, and for the ELD if running anything other than a PR4.
    The 2 extra vtec wires could be used for something else... That's why I didn't make them optional for the extension harness. If I am building you a custom harness they can be left out and I can knock off another $5-10. Fan wire is not absolutely necessary, but allows the option of running an integra performance radiator or other rads without a fan switch, another $5... Basically let me know what you want. If you want just a harness with the distributor and O2 wires, I can do.
    Personally, I like to keep all my options open, and this is why I made these deluxe. If people want a scaled down version, I'll build it for a reduced price. I'm not going to go below $200 for the complete setup though.
    CARDONE SUCKS.
    AZ
    for the amount of work involved i would definitely pay this... especially since i've seen these first hand and have had a hand in the gathering process... so time consuming. i've also had experience just retaping and looming and soldering new connectors onto an engine harness and i really wouldn't mind paying extra money to have it done for me.
    dead white and blue
    Ill pay what you want for indeed. all the work put into this thats cheap
    87roach's Avatar
    Mar 2007
    87 Hatch
    Summerland, B.C.
    I stand corrected, the work is top notch. I can't wait to swap this stuff in!
    Andrew.
    lol just to do my mini tuck i used over 100ft of wire, and it took me 2 3hour nights to get the wires run. I didnt even de-pin them lol. Just cut stripped, then resoldered.
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    What would it cost me to just get all the connectors? I would really prefer to do it myself, but ive got no clue where to get the connectors. Those harnesses look amazing though!
    Its not that i dont trust your work, its just that i'd like the experience of doing it myself, and if i want to super tuck the harnesses i can!
    '89 SE-i Coupe
    Awaiting Garage
    Sep 2006
    Tucson, AZ
    All the connectors? How do you want them, wire leads or depinned? Are you going to need them for the ecu jumper as well?
    I am planing to do an engine tuck on the A20 with a B18 manifold at some point... Should look sick! Got to finish building the motor first though...
    CARDONE SUCKS.
  1. seat harnesses?
    By 88lxi-shortram in forum Classic Honda Community Chat
    Last Post: 09-24-2010, 05:46 PM
  2. FS; complete disc conversion from SE-I
    By powderkey2 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-09-2007, 02:50 PM
  3. OBD0 - OBD1 conversion harnesses found...
    By Hash_man_Se_i in forum 3geez Accords
    Last Post: 11-29-2004, 05:55 PM
  4. Efi conversion complete!!
    By ryansaccord in forum 3geez Accords
    Last Post: 05-27-2003, 09:45 PM
  5. two harnesses
    By roni-sei in forum Interior & Exterior Care
    Last Post: 12-04-2002, 08:02 PM
