Results 1 to 20 of 20
Thread: Machining, Koni's and Eibachs! (56k Dont bother)
    Ichiban's Avatar
    North of You.
    Well, I got around to installing my Eibach springs, courtesy of 2ndgenguy, and my Koni red's last weekend.
    Enjoy the photo walk through.
    Here is the car before the lowering
    Ride height at the front.
    Rear.
    Taken apart.
    Koni's
    ICHIBAN!
    "Now, even more better!"
    Ichiban's Avatar
    North of You.
    Re: Machining, Koni's and Eibachs! (56k Dont bother)
    After about a minute of flailing with the spring compressor and strut on the floor, I got tired of that. Found a lathe just laying around, so I used that as a vice.
    The Koni instructions recommended grinding the crimp off of the struts. Grinding. I fucking hate grinding.
    The front struts went in just like they were supposed to.
    ICHIBAN!
    Ichiban's Avatar
    North of You.
    The rears, on the other hand, didn't. The factory housings were about half an inch too long for the Koni's to fit properly, and the counterbore that the knurled cap of the Koni presses itself into was too far up the housing to allow me to get the nut onto the stud at the bottom of the shock.
    In what would be a showstopper for most, I simply bored back the counterbore, and turned the housing to length.
    You can see here how much too long the housing is for the Koni insert. On this one, I turned it to length with the insert inside, the second one I simply machined to length before installing the insert.
    It comes apart before it goes back together.....
    And Voila! In a day or two after the springs settle, I'll update you all with the new measurements!
    ICHIBAN!
    Looks good, Konis are ftw
    looks like you got to make the springs settle a bit more....more pics after a nice drive in the twisties
    Looks good.
    How much of a drop is it going to be after it settles?
    looks really good..
    looks sweet! i believe you are the first lowered 2g hatch =O
    Yeah first lowered hatch on the forum! It's already looking just like it should! Where did you set the Konis?
    Ichiban's Avatar
    North of You.
    1/4 turn out from full resistance. It feels perfect.
    ICHIBAN!
    did you turn them from soft to hard or hard to where u want them, cause konis have a tendancy to be stiffer than others if wound back the other way. Mine are all set on half but its not stiff enough
    Nice. Now get some wheels
    Oct 2000
    '88 Accord LX-i
    Connecticut
    nice score with the parts. Hopefully it settles soon because it looks like the saggy stock springs were lower. lol
    '88 LX-i Coupe --- LS/Vtec
    lol mine are on full stiff
    LX User denhonda's Avatar
    Apr 2006
    82 DX & 85 EX Accord Sedan Hondamatics
    UK
    I look at these threads with great interest as I want my '82 lowered as it looks ridiculous with such a massive space between the tyres & the arches.
    Only... there doesn't seem to much of a difference between before & after?
    Granted, I know your springs still need to settle but I'd like to see a drop of another inch or two to get it looking right. Especially if you're gonna fit lower profile tires in the future. It seems an awful lot of work (nicely done I must say) for only a little gain.
    I'll look out for the updated pics/measurements & then I'll maybe have to eat my words!
    Ichiban's Avatar
    North of You.
    The springs have actually settled in quite nicely, the wheel gap is still large, but you can tell the car is definitely hugging the wheels more. The improvement in handling is simply beyond description. It's obvious now that the cheapo 185/70 R13 Motomaster doughnuts are the weak link now. I'm gonna drive it a bit more, then take the "after" pictures and measurements sometime this week.
    Oh yeah, and I set the Koni's to full stiff, then backed out 1/4 turn. I really couldn't tell any difference by pulling by hand on the shaft from full stiff. Full soft provided almost no resistance by hand.
    ICHIBAN!
    I can tell you, Den, it's a very subtle drop. Only 1.3 inches. Even my car still isn't really slammed, but it now looks just the way it should be. It looks good without looking obviously lowered. Though, I will admit, I desire lower, and am plotting new things.
    Apr 2006
    UK
    I ain't into lowered cars as such but I've always thought the 2geez sat too high... except for my old rusty '85 which was always about an inch or so lower than the '82 when parked nose to nose. And that handled really well but I was never aware that it had any modifications...
    My current '85 runs standard 165SR13's but they were newly fitted before I got the car & do nothing for the handling. I might swap the 15" wheels - 195/50 - over to it meantime to see what difference that makes & have an even bigger gap in the arches!
    This post from 2007 is relevant to this thread.
    https://www.3geez.com/forum/showpost....3&postcount=28
    Ichiban's Avatar
    North of You.
    And lathe I did!
    ICHIBAN!
  1. POST LINKS HERE for CNC MACHINING, MATERIALS, OTHER PROJECT NEEDS
    By A20A1 in forum Restoration & Custom Fabrication
    Last Post: 05-16-2008, 12:44 PM
  2. well i got after math pics 56k dont bother
    By buttaz1 in forum Classic Honda Community Chat
    Last Post: 01-22-2007, 08:21 AM
  3. nvm dont bother looking
    By wannaswapab20 in forum 3geez Accords
    Last Post: 08-15-2003, 07:10 PM
  4. new coilovers over eibachs?
    By mykwikcoupe in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-16-2003, 10:06 PM
  5. eibachs or dropzones
    Last Post: 12-06-2002, 04:15 PM
