Results 1 to 8 of 8
Thread: Transmission input shaft seal
    My Accord started leaking bunch of transmission fluid under the car, coming from bellhousing/block area. I'm 100% sure its transmission fluid, not engine oil and I'm positive its coming from input shaft seal.
    My question is, how hard is it to do it myself? Do I need to rip open the gearbox or simply dropping it off from the engine and replace the seal just like that will do? By the scale of 1-10 how hard is it going to be?
    LXi User 79cord's Avatar
    Melb, Aust.
    Re: Transmission input shaft seal
    I don't think you'd need to disassemble the gearbox but like you say you'd definitely need to separate it from the engine & probably remove the driveshafts in order to move it about. Similar to replacing the clutch.
    I replaced my Preludes g/box with its engine in place but ended up having to remove my Accords engine & gearbox when I needed to do its clutch due to other issues (broken alternator bracket bolt) so can't really comment upon how easy that would be.
    I want to say that I don't think you can pull the input shaft seal from outside the transmission. But maybe I just never noticed it because it's behind the throwout bearing, and I usually replace that first thing.
    I dunno, I've googled and seems like the gearbox has to be torn apart.
    I guess I should take it to a mechanic then. I hate them
    Mechanics go home!!!! Don't do it dude. You got the skilz. Just do it!
    Not with something with gears
    I messed up a power drill gears before and I definitely don't want to screw this up!
    ^^^ lol damn how can u mess up a drill.
    Anyways its okay they are pretty scary inside, i managed to swap a diff in mine tho ages ago. you just have to put everything back where it came from (most of the time stuff only fits one way anyway) Taking lots of photos helps a bit.
    Make sure you move the box and take it to them, its going to cost heaps.
    im 99% sure you have to tear it down, and since its apart you mine as well replace the bearings and shit shouldent cost to much for a rebuild kit ^_^ i plan on rebuilding a SI trans for my civic, after reading many how tos it doesent seem as bad as it sounds
  1. replace transmission-axle seal?
    By timber_cruiser in forum 3geez Accords
    Last Post: 11-22-2006, 04:17 PM
  2. Help! (transmission seal)
    By 895spdforfree in forum 3geez Accords
    Last Post: 06-26-2005, 09:19 AM
  3. Help! (transmission seal)
    By 895spdforfree in forum EFI Tech
    Last Post: 06-22-2005, 02:09 PM
  4. Cam Shaft Seal
    By mag_pbg in forum 3geez Accords
    Last Post: 05-24-2004, 04:00 PM
