Results 1 to 5 of 5
Thread: Need help about bearing!
    Dear pals!
    I would like to ask you for help, because in my country there is no possibility to order 91103-PC8-J01 bearing for gearbox (http://www.hondapartsnow.com/transmi...mainshaft.html marked 16-th)
    I am waiting about month for this part, and always receiving messages from all suppliers - "Rejected ". I don`t know what to do. The only way is to reassemble my gearbox with old bearing! Any advices?
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Re: Need help about bearing!
    Honestly, I would reuse it if it looks/feels to be in good shape. Those needle bearings don't get much wear as they only serve to idle the gear when not engaged. Most rebuilds typically involve only replacing the 4 main bearings that support the shafts.
    CARDONE SUCKS.
    I'd just take it around to different tranny shops asking if they have something sitting around on their shelves. If you have a bearing supply place you can try that too. How bad is the one you have? Do you have pics?
    There are several good bearing companies in the EU. SKF is one name that comes to mind. I would find a regular bearing supply company and bring the bearing to them to look at. The dimensons are on the Honda website you provided. There should be something out there for you.
    Smile Re: Need help about bearing!
    Thanks for replies dudes! Unfortunately idon`t have pictures of this bearing but i have checked them properly and i didn`t find anything criminal in his work I have ordered once again this part from Germany (should waiting about 2 weeks) anyway this is the only one solution for this problem. Honestly i don`t see any problems with this bearing, but my technician told me that under loading there is some freeplay in it (it` s hard to believe, but this is the only one probable reason of strange noise at idle from gearbox). Thank you once again.
  1. Pilot Bearing: Yay or Nay?
    By Hecubus84 in forum 3geez Accords
    Last Post: 03-18-2008, 06:13 PM
  2. Throw-out bearing, maybe
    By w261w261 in forum 3geez Accords
    Last Post: 09-23-2007, 08:26 PM
  3. OEM throwout bearing?
    By 87LXiR in forum 3geez Accords
    Last Post: 06-03-2007, 08:36 AM
  4. Bearing replacment
    By pimp_n87LXi in forum 3geez Accords
    Last Post: 06-16-2004, 07:00 PM
  5. $600 for Wheel Bearing? WTF?
    By Longevity in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-18-2002, 04:00 PM
