Results 1 to 14 of 14
Thread: My antenna only goes down half-way...
    ...then it stops and starts to click. It goes all the way out, though...
    Any ideas?
    Re: My antenna only goes down half-way...
    try lubricating the mast to see if that helps.
    if not than you will need to replace the mast assembly
    Lubricated the lower half (outer layer of metal) of the mast and it goes all the way up and down by itself! yeee
    LXi User ecogabriel's Avatar
    Apr 2008
    Atlanta, GA
    What did you use? Mine does the same thing, but if I push it a little bit it will go all the way down. I though of using WD-40 or similar...
    LX User Bluntman's Avatar
    Apr 2009
    1988 Honda Accord LXI
    Orange County Cal.
    Quote Originally Posted by ecogabriel View Post
    You can lube it and Scotch brite it to get off the crap from the elements if it is sticking from gunk on the actual antenna itself.
    My '66' GT I built. My first Hot Rod magazine Cover "Summer 85". I've had it for 32 years, since I was 18. It's a trailer queen. 289 Hi-po, t-10 Toploader 4speed, 9 inch rearend.
    ^ These are both of the things I did.
    ...that's what she said
    Nov 2000
    Don't use too much of anything that can attract dust and dirt. I had the best results just keeping it really clean with the occasional use of a detailing spray, which has a very light wax in it. Ultimately, the plastic drive cable broke during one of our less than common cold snaps a couple of years ago. I was so tired of keeping the thing working for 20+ years that I "treated" myself and replaced it with a manual antenna. While mine always worked, it would often stick and had to be aided to reach full extension. These types of antennas are, thankfully, not in use anymore.
    SEi User obdriver6's Avatar
    Nov 2008
    1989 Accord LX-I Coupe
    Las Vegas, NV
    I'm going to try this cause I have this problem too.
    1989 Honda Accord LX-I 300K+
    Build Thread
    Mar 2012
    89 Accord lxi
    Reading, PA
    mine doesnt move at all
    Quote Originally Posted by HelenKellerrr View Post
    what year and make some of them arent power...
    Mar 2012
    89 Accord lxi
    Reading, PA
    89 lxi. It's powered, just doesn't move. plus its bent to hell and i''m too cheap to buy something i hardly ever use.
    ya when i get mine up and running again ill be deleting the antenna all together never use fm anymore
    Nov 2000
    Now that I have an OEM type manual antenna I just leave it up all the time. I did look at various types of thin wire antennas that stuck to the inside of the windshield or other types that mounted under the dash. Ultimately, it was easier to go with an OEM type.
  1. half antenna mast switch
    By agol in forum For Sale
    Last Post: 08-16-2010, 12:52 PM
  2. Half Accord, half Prelude
    By Gasoline Fumes in forum Classic Preludes
    Last Post: 06-11-2007, 08:54 AM
  3. half an accord
    By acco-R-d in forum Classic Honda Community Chat
    Last Post: 09-13-2006, 09:27 PM
  4. half shaft help
    By jdragon in forum Classic Honda Community Chat
    Last Post: 03-05-2004, 06:10 PM
  5. Power antenna v. manual antenna masts
    By offthahook in forum 3geez Accords
    Last Post: 09-08-2002, 03:53 AM
