hey guys i have an 88 dx carb and this morning i was driving and i noticed my battery light was on i already put a new battery in but it wont turn off thnx guys
probably means your alternator isn't charging.....your old battery might not have been bad and even if it was, it could have been caused by the alternator going out..could've killed a cell
Go to autozone or shmucks or whatever autoparts store is near you, and have them test your alternator. That'll tell you if it's bad or not.
most likely the alt is bad
have fun pullin that driverside Axle
You can actually pull the alt on the carb models without having to pull the driver side axle. Last time I changed one I snaked it under the manifold and out the passenger side. The only trouble I had was getting it around one of the heater hoses, and I think I had to disconnect the speedometer cable.
yeah...does your stereo work...when mine started to die the stereo had little noise....also check your batt terminals that they have a good ground.
