how do you check for codes on an 88 accord lxi fi is there something you have to do to get the light to blink on the computer or will it blink itself if there is a code
This has been posted before, so here is the info.
Comment posted on Jul 01, 2008
How to check your Check Engine Light codes:
1. move driver seat all the way forward.
2. locate the box on the floor.
3. locate the small plastic window and pop it open.
4. turn the ignition on.
5. count how many times the light blinks.
6. refer to the table below
CODES for 86-89 accord and 85-89 prelude
00 LED FLASH(s) ECU
01 LED FLASH(s) 85-98 Accord
Oxygen Sensor "A" (Primary)
defective circuit or unplugged / defective sensor
02 LED FLASH(s) 85-89 Accord
Oxygen Sensor "B"
03 LED FLASH(s) 85-98 Accord
MAP Sensor (Manifold Absolute Pressure)
04 LED FLASH(s) Crank Angle
05 LED FLASH(s) 85-98 * Accord
mechanical problem / disconnected piping
* exc. 94-95
06 LED FLASH(s) 85-98 Accord
ECT Sensor (Engine Coolant Temperature)
07 LED FLASH(s) 85-98 Accord
TP Sensor (Throttle Position)
08 LED FLASH(s) 85-98 Accord
TDC Sensor (Top Dead Center)
09* LED FLASH(s) 85-98** Accord
CYP Sensor (Cylinder)
* not a valid code for any throttle body injection Hondas
** not a valid code for V-6 engines
10 LED FLASH(s) 85-98 Accord
IAT Sensor (Intake Air Temperature)
12 LED FLASH(s) 85-98 Accord
EGR Lift Sensor (Exhaust Gas Recirculation)
13 LED FLASH(s) 85-98 Accord
BARO Sensor (Atmospheric Pressure)
14 LED FLASH(s) 88-98 Accord
IAC Valve (Idle Air Control)
IAC VALVE HELP
15 LED FLASH(s) Ignition output signal
16 LED FLASH(s) fuel injector
17 LED FLASH(s) 88-98 Accord
VSS (Vehicle Speed Sensor)
Thanks to my buddies at 3geez for the info, When That check engine light comes on bring the car to a stop DONT TURN IT OFF! and follow the instructions Posted above That WILL Narrow it to the the Exact problem. Good Luck Man!
ok mine isnt flashing at all does that mean there is no codes or is the ecu bad
