The best I can find is this
Wiring Description for the 24-Pin Connector
Pin Wire Color Con nects to
1 White/Blue Remotely Adjustable Dual-Zone Piezo Sensor input
2 White/Violet Pulse out before remote start (-) and upon disarming
3 Black/Gray RPM input
4 Blue/Green Reverse light input (+)
5 White Valet switch input (-)
6 Orange Optional sensor input
7 White/Black Hood trigger input (-)
8 Gray/Yellow Trunk trigger input (-)
9 Blue/White Brake light input (+) (and relay shown if manual transmission)
10 Black Ground for Dual-Zone Piezo, optional sensor, LED and valet switch
11 Red Power for Dual-Zone Piezo, optional sensor
12 Black Ground (-)
13 Gray/Green Door lock output (+) or (-)
14 Green Armed output (-)
15 Violet/White Pulse out after remote start (-) and upon arming
16 Gray/Violet Auxiliary A output (-)
17 Gray/Orange Door unlock (+) or (-)
18 Red Battery (+) with 5-amp fuse
19 Violet LED output
20 Yellow Siren (-)
21 Blue/Black Heater 2 relay output if needed (-)
22 Brown/Red Interior light supply input (+) or (-)
23 Gray Door trigger (+) or (-)
24 Blue/Orange Negative out when started
Wiring Description for the 12-Pin Connector
1 Red Battery (+) with 30-amp fuse
2 Gray Heater/AC output
3 Green/Blue Coil side - ignition (+) (and relay shown if manual transmission)
4 Red Battery (+) with 30-amp fuse
5 Red Battery (+) with 20-amp fuse
6 Brown Parking light output (+)
7 White/Green Key side - starter input (+)
8 Orange Accessory output
9 Brown Parking light output (+)
10 White/Blue Starter side - starter output (+)
11 Not used Not used
12 White/Brown Key side - ignition input (+)
