Results 1 to 16 of 16
Thread: cooling fan not working
    May 2009
    88 honda accord lxi 2dr
    indian trail nc
    just as the title says fan is not working when it gets up to temperature and when i cut the key off the sub cooling fan comes on but the other one never comes on at all anybody have any idea i have checked all the fuses and swapped the relay and still nothing
    conozo's Avatar
    Fort Wayne, Indiana
    Re: cooling fan not working
    have your shorted the contacts on the plug that goes into the thermosensor to verify they fans are getting power and the relay works.
    1988 Honda Accord LSDX-I
    May 2009
    indian trail nc
    no how do i do that which plug is it
    May 2009
    indian trail nc
    ok i shorted the plug and the fans came on so i went and got a new thermosenser switch and its still doing the same thing
    Apr 2009
    1987 Accord Lx-i
    Gaffney, SC
    then the problem lies in your wiring if the sensor didn't fix it.. are you sure you replaced the right sensor? There are 2 right next to each other that look pretty much identical
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    The fan switch is on the bottom of the radiator. Are you overheating? Do the fans come on with AC?
    A faulty thermostat or air in the system will cause the sub cooling fan to come on as you describe. Change your thermostat and bleed the coolant.
    CARDONE SUCKS.
    May 2009
    indian trail nc
    yes i changed the one on the bottom of the radiator and it is still doing the same thing could it be one of the other ones near the thermostat it runs hot after idling for about 15-20 minutes bc the fan never comes on until you turn the car off then the sub cooling fan comes on but not the big that is supposed to come on
    May 2009
    indian trail nc
    and as soon as you turn the key switch back on the sub cooling fan goes off
    LX User Bluntman's Avatar
    Apr 2009
    1988 Honda Accord LXI
    Orange County Cal.
    Also in the mainfuse box there is
    Cooling fan relay
    sub cooling relay
    cooling fan fuse
    sub cooling fan fuse
    cooling fan timer fuse
    Check all maybe you missed something there. Fan timer fuse maybe
    May 2009
    indian trail nc
    if the relay was bad the fan wouldnt come on when i jump the sensor plug would it??
    Apr 2009
    Orange County Cal.
    Go look at the fan timer fuse, just out of curiosity, you can also switch the two relays around and see if that fan comes on when it heats up.I believe they take the same relays.
    May 2009
    indian trail nc
    i have checked all the fuses and i switched the relays around as i have already said in the post the window relay and fan relay are the same
    1989 Honda Accord Lx-i
    yeah i got a similiar problem, my car would get too hott but only one fans works which is the left side, the right side is the ac fan which doesnt work and really dont need it,unless you want ac, but i just replaced the cap, and now no more heating :-)
    Sep 2006
    Tucson, AZ
    The aux/sub fan switch is located on the thermostat housing, before the thermostat. It is the larger of the sensors, and has a green connector. If the thermostat isn't properly opening, there isn't going to be a high enough flow of coolant to flow through the top of the radiator and be hot when it gets to the bottom, where the main fan switch is located... Since the aux fan switch is before the thermostat and isn't dependent on flow, it will signal the timer to run the aux fan.
    Change the thermostat and bleed the cooling system. Use the honda part, it makes a difference.
    CARDONE SUCKS.
    May 2009
    indian trail nc
    i bled it already but i will try again see if more air is in there in just a bit
    May 2009
    indian trail nc
    the thermostat was stuck thanks for the help im having other problems now please check out my other thread not revving up fully
  1. Cooling fan
    By mark_salad_bar in forum Classic Honda Community Chat
    Last Post: 06-03-2008, 08:55 PM
  2. cooling
    By honda in forum 3geez Accords
    Last Post: 04-16-2006, 10:08 AM
  3. cooling fan not working..i think
    By od2681 in forum 3geez Accords
    Last Post: 10-10-2004, 02:04 PM
  4. Hot Day + A/C + Cooling
    By mindlos in forum 3geez Accords
    Last Post: 07-07-2004, 07:29 PM
  5. Cooling fan/s never off!!!
    By blahblahblah in forum 3geez Accords
    Last Post: 05-24-2004, 03:32 PM
