I know there has been some people saying that the H23 rods are not only stronger but, are the same size as the B20A5 so I wanted to clear the air.
Well I just got off the phone with my Tech Rep at JE Pistons and he informed me of the following.
B20A5 rods are 142.75mm(5.62")
H23A Rods are 141.5mm(5.57")
So yes the H23 rods are stronger, but shorter. So if you use them with stock pistons your going to loose some compression(less Power) unless you shave the block 1.25mm(.049")
Or like many have said, use H23 rods with the B16 pistons(just bore the pistons to accept the 22mm wrist pin.
