Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
Thread: 70mm TB on edelbrock intake/ stock TB
    AZ
    Re: 70mm TB on edelbrock intake/ stock TB
    Quote Originally Posted by mykwikcoupe View Post
    when i look omn ebay the model I have is listed as used for honda, why wouldnt the idle air circiut work without the TB? the water is the only thing that runs from the TB to the IACV right? why couldnt I just bypass the TB and go striaght to the IACV?
    the iacv uses air not water... that's just unnecessary intake preheater bullshit... or deicing stuff...
    it's listed for honda because it's for drag purposes not normal driving...
    i can't remember the name of the company but there is one that makes cheap honda tb's that are 68-72mm
    dead white and blue
    Joay's Avatar
    Sep 2008
    Misty Beige 1988 LXi Coupe
    Quote Originally Posted by LX-incredible View Post
    The stocker is a 88-89 TB with the round connector, correct?
    I had to buy 3 or 4 b series throttle cables and brackets before I found a combination to work... S2 manifold only works with the TypeR bracket. The 94-01 Integra cable is the perfect length with the S2 TB and IM, but you need to grind the pedal end to fit.
    You can sort of see the TypeR bracket in these:
    Anyway, I have a bunch of brand new B18 throttle cables and brackets. Get some measurements, I might have a combo that will work...
    I've got the center console and seat out of the auto to find out how I want to route your harness. Should be done Monday.
    That a B18 manifold?
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Yes, B18A, B18B, B20B, and B20Z.
    CARDONE SUCKS.
    you got the b18 s2 manifold? you got close pics of the back of it...also what tp did you use?
    Sep 2006
    Tucson, AZ
    Yes. S2 68mm TB.
    Back or underside? Nothing on the underside, IACV, brake booster, and single vacuum port on the back.
    CARDONE SUCKS.
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    sweet sounds good then, I was just worried about idle and Im not really caring about performance right now I just dnt have many other options with this intake mani. Its a beast
    Idle was pretty damn good when I had it. It actually would rev up and down, but that was a big vacuum leak that I had, fixed and was back to normal.
    -Gio
    My E85 Turbo Build
    5280FEST
    Washington
    did I buy this stuff from you? Sorry I just cannot remember. If I efectivly block off the idle circiut how would I control idle speed and such.
  1. Pictures of the engine with the Edelbrock Manifold (56k forget it)
    By carotman in forum Classic Honda Pics & Videos
    Last Post: 07-26-2005, 12:35 PM
  2. FS: Stock Intake from LXI
    By Nate2310 in forum Trading Post
    Last Post: 04-05-2004, 01:11 PM
  3. F/S stock intake
    By lightbulblxi in forum Trading Post
    Last Post: 04-04-2004, 11:25 PM
  4. stock intake vs aftermarket
    By 1988_5spd_lxi in forum Performance
    Last Post: 08-16-2003, 06:14 PM
  5. JG Edelbrock 89 accord intake on ebay!!?!
    By myaccord7 in forum Trading Post
    Last Post: 06-30-2003, 11:21 PM
