Results 1 to 15 of 15
Thread: Rebuild A20 FI
    Jan 2009
    1989 Honda Accord LX-I Coupe
    Houston, TX
    Rebuild A20 FI
    i have a 89 lxi manual and i want to rebuild my stock engine to make the car go faster which parts should i use?
    Re: Rebuild A20 FI
    depends how fast you want to go LOL?
    Re: Rebuild A20 FI
    High compression forged pistons, titanium rods, custom stroker crank fully balanced and knife edged, aluminum flywheel, custom aluminum pulleys, oversized valves, radiused valve seats, heavy port and flow job, adjustable cam gear, nasty cam grind, standalone ECU, individual throttle bodies, distributorless ignition, custom header with 2.25 inch mandrel bent exhaust
    i think that's bout it. pretty easy.
    Re: Rebuild A20 FI
    Quote Originally Posted by Nik247 View Post
    What it comes down to is how much are you willing to spend on your 20+ year old car and how dedicated you are going to be on having this done on a 3rd Gen.
    Alot of new people come here and have lots of plans for their Accord and give just up when they realize the funds needed and the lack of aftermarket support.
    I wish you luck in your build and hope to see you stick with it
    And Welcome to the Forum
    Re: Rebuild A20 FI
    ^^^ Pico makes a good point. But I am going to supplement his point:
    What are you going to do to a Civic (or any generic import) to make it fast? Sure a Civic has tons of aftermarket support. But it's a market flooded with low-quality garbage, and all the good stuff is retarded expensive. What can you do to make a D16 fast? Bolt ons? CAI? Exhaust? You can do that to the Accord easily enough too. Once you dig into the actual motor, it's all the same for nearly any car really. I doubt you can build an NA D16 for much cheaper.
    Jan 2009
    Houston, TX
    Re: Rebuild A20 FI
    thnxs and ya i do plan to keep this car for a long time preferbly for atleast 5yrs if not more i love my car i only plan to put bout 4grand to the work for now i just want it to go a little faster but want to keep it na dont want to turbo
    Re: Rebuild A20 FI
    4 grand in the motor?? if so u can have a health lil n/a beast...
    Jan 2009
    Houston, TX
    Re: Rebuild A20 FI
    well 4grand for doing motor rebuild and some other work too but where is a good place to buy parts?
    Re: Rebuild A20 FI
    how much are you looking to spend on the motor itself?
    SEi User
    Jan 2004
    Re: Rebuild A20 FI
    Well I'd keep the block stock just put in some nice new honda pistons preferably A20A4 ones with .3mm overbore, just have the whole assembly blueprinted properly either by yourself or by a engine shop but one thats trustworthy!! The parts have to be balanced perfectly and clearances exact and not left to factory fit!
    Then spend the money you do have on the headwork and the exhaust and induction system you choose and do something about the ECU and Ignition with custom ECU.
    You'll have a reliable setup thats got some go go to it and still be fuel efficient!
    Joay's Avatar
    Sep 2008
    Misty Beige 1988 LXi Coupe
    Re: Rebuild A20 FI
    Colt Cams
    Golden Eagle (con rods)
    JE (pistons)
    Bisimoto (valve springs)
    There are others, but those are some of the best in the business. For head & block work, ask around for a reputable machine shop in your area. That stuff can be handled by anyone.
    Your crank, honestly, should be fine for like 200whp. People build monstrous racing engines with stock Honda crankshafts. If you have a couple hundred left over and nothing to do with it, you could get that knife edged, but it isn't really necessary.
    Jan 2009
    Houston, TX
    Re: Rebuild A20 FI
    thanks
    LX User russ_512's Avatar
    May 2009
    1989 honda accord lx-i
    south carolina
    Re: Rebuild A20 FI
    when people say reseach you will find the answer they are right this is a helpfull thread lol
    i have an 89 lxi and i was gonna completly rebuild my a20a3 and try to turbo it bu i dont know if ill be able to yet
    im gonna try to do it in dec cause ill be back from basic so ill have enough $
    Re: Rebuild A20 FI
    ummm boost...
    Re: Rebuild A20 FI
    some guy here has a turbo kit for sale and its mad cheap
  1. Rebuild
    By Scott in forum 2geez Tech & Performance
    Last Post: 05-22-2010, 10:46 PM
  2. rebuild kit under $300
    By 88Lxi Guy in forum 3geez Accords
    Last Post: 06-03-2009, 11:07 PM
  3. Rebuild or Buy new ones?
    By mkymonkey in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-18-2008, 12:04 PM
  4. to rebuild them or not to rebuild them, that is the question
    By ZackieDarko in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-20-2007, 06:46 PM
  5. 89 lx rebuild
    By z3bra in forum 3geez Accords
    Last Post: 10-29-2004, 02:06 PM
