I found this info on a great site with many articles about engine build and such.
Because many of us do engine rebuilds I thought this info may be useful to break-in engine correctly to avoid further issues.
Cylinder Wall Preparation
Hone Cylinders with 280 grit, followed by a light 380 grit Brush with a 60 degree cross-hatch per Honda’s instructions.
Do NOT allow your machine shop to exceed the recommended clearances, or excessive cylinder oiling will result!
For faster ring seating use 280 only.
We use and recommend the use of Sunnen Automatic Honing Equipment for cylinder wall preparation.
Engine Break-In (1000 Miles)
Use only genuine Honda Oil Filters !!
Use 05-30 non-synthetic motor oil ONLY !!
Do Not operate the engine over 3,500 RPM during the first 200 miles of driving. You may increase the engine speed by
500 RPM for each successive 200 mile increment of break-in.
Replace the Honda Oil Filter after the first 200 miles of operation.
Change the oil and filter after 1000-1200 miles of operation. You may use synthetic, or a quality non-synthetic oil.
We use and recommend the use of 05-30 Mobil 1 motor oil.
Minimum Piston to Cylinder Head Clearance
With Stock Factory Rods: .045”
With Forged Aftermarket Rods: .040”- .047”
Minimum Piston to Valve Clearance
Intake Valves: .050”
Exhaust Valves: .060”
Minimum Valve to Valve “Clicking” Clearance .040”
al info taken from TheOldOne
